Author Topic: Tag Light Wire Retainer  (Read 772 times)
Offline rrenz
« on: March 03, 2018, 09:34:57 AM »
Was this a common practice to attach a wire retainer to the tag light? Starting to get into some nitpicking details on my car and I ran across this photo going through unrestored threads while working on my rear taillight buckets. Haven't seen this too many times if at all that I can recall.
Ryan
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
Re: Tag Light Wire Retainer
« Reply #1 on: March 03, 2018, 01:31:43 PM »
If you are referring to the one in the upper RH corner of your picture, yes. It's strap 376914-S used from 64 thru 68.
« Reply #2 on: March 03, 2018, 03:39:40 PM »
If you are referring to the one in the upper RH corner of your picture, yes. .......
+1
« Reply #3 on: March 03, 2018, 06:53:22 PM »
To add to Jim's post the pre punched hole in the structure indicates that the intention was there for the strap to be installed regardless of if the strap made it on the car or not. They typically made it on the car however as mentioned.
Offline rrenz
« Reply #4 on: March 03, 2018, 07:00:59 PM »
ok great. Thanks
Ryan
C-4 Automatic
Build Date Jan 21st
« Reply #5 on: March 13, 2018, 10:19:18 PM »
NOTE: Split the whole terminology discussion off to its own thread in the Lounge
