Author Topic: '66 factory a/c installation  (Read 1080 times)
Offline socalgt
« on: March 02, 2018, 09:47:40 PM »
I know it would be easier to do before...but....how difficult would it be to install the lines to the under dash a/c unit after installing the unit to the dash?  I'd like to reinstall the unit to the dash but I'm not ready to attach the lines.
        Thanks....
Re: '66 factory a/c installation
« Reply #1 on: March 03, 2018, 12:28:43 AM »
It's possible, but consider that you need 2 wrenches to tighten these, otherwise you'll risk cracking the evaporator core fittings or surrounding area.  Personally, I would leave it off until I was ready to attach the lines to the unit.
Offline socalgt
« Reply #2 on: March 04, 2018, 10:22:02 AM »
Thanks for the advice...I'll take it.
Offline socalgt
« Reply #3 on: March 06, 2018, 04:01:19 PM »
The hoses have their natural bend from prior installation.  I was thinking of installing the hoses and not quite tightening them all the way in case they need to be altered a bit to smoothly fit through the firewall and retain their original routing.  I don't know how flexible they'll be if I tighten them all the way down.  Any thoughts?
        Thanks.....
Offline socalgt
« Reply #4 on: March 06, 2018, 07:20:57 PM »
Regarding the yellow wire with the in line fuse on the a/c harness.......I understand it attaches the ignition switch.  I assume it will be obvious where it attaches when I look?
« Reply #5 on: March 06, 2018, 07:22:05 PM »
there is a stud on the back of the ign. switch.
Offline socalgt
« Reply #6 on: March 06, 2018, 08:14:15 PM »
Got it.....pretty obvious....not the easiest to see, but easy to feel.  Got the power to the a/c unit....
                                                              Thanks.....
Offline 196667Bob
« Reply #7 on: March 07, 2018, 11:11:04 AM »
Maybe the attached will help.
Bob
MCA 04909
