Author Topic: Grille Rivets  (Read 3035 times)
Offline must69
Re: Grille Rivets
« Reply #15 on: June 27, 2018, 08:35:00 PM »
Pretty Clever Jim.  I did not realize Harbor sold a press like that.
Phil
Offline must69
Re: Grille Rivets
« Reply #16 on: January 27, 2019, 09:22:01 PM »
Jim, in your reply you mentioned the ashtray rivets.  I am about to start working on the ashtray. Any recommendations for replicating the original “galvanized” finish?
Thanks.
Phil
Re: Grille Rivets
« Reply #17 on: January 28, 2019, 12:40:33 AM »
Phil,
The plating shop I use has a new zinc finish called "dull zinc". I say new, it's been in use for about three years. I prefer to glass bead blast everything I send and keep it super clean - no fingerprints (oily hands leave marks). That combination replicates cad plating closely. There is a technical problem with standard zinc plating for ash trays, the zinc has a tendency to be deposited on the outside of the ash tray. The inside gets some plating but to get a decent look inside, the outside will have to get more. There are fixtures used to deposit zinc on an inside surface but they get expensive.
Offline DKutz
Re: Grille Rivets
« Reply #18 on: January 28, 2019, 05:28:28 PM »
Rick at NPD just posted on VMF that they will be carrying grilles with correct rivets and colors soon.
Offline NEFaurora
Re: Grille Rivets
« Reply #19 on: February 06, 2019, 12:14:15 PM »
"Rick at NPD just posted on VMF that they will be carrying grilles with correct rivets and colors soon."
Yeah, I had sent Rick an E-mail and pics of the available "OEM" looking rivets that are sold today that are fully available.  Rick sent all the info to his Overseas supplier of the Grilles..
:o)
Tony K.
MCA#70001
Offline must69
Re: Grille Rivets
« Reply #20 on: February 17, 2019, 08:43:08 AM »
Jim, were you happy with the finish on your ashtray?  Can I ask where you had it done?
Thanks.
Phil
Re: Grille Rivets
« Reply #21 on: February 17, 2019, 12:27:15 PM »
- were you happy with the finish on your ashtray?  Can I ask where you had it done?
Yes I was happy. I'm in Silicon Valley where many hi-tech plating shops exist. My work is done on a "special" basis, minimal paperwork, no due date and a lot charge is applied. It is a car friendly shop, which helps.
