Author Topic: Top Loader rods and levers  (Read 1273 times)
« on: February 26, 2018, 06:02:30 PM »
Is the Branda rod and lever assembly for a Top Loader (T/L) of concours quality?
I'm about ready to pop on a Ford 67 shifter case and wonder if I should buy the Branda rods and levers or the less than perfect originals I'm being offered. I'm not even sure the rods are correct as I thought by 67 the T/L rods no longer had part numbers on them.
I see only one complete part number visible as a C6OA-7326-A -- the other rod has C6OA-xxx28-x.
The numbers on the levers are C6OR-7290-C, C4ZR-7C165-A and C6OR-7285-D.
« Last Edit: February 27, 2018, 11:01:00 AM by Bossbill »
Online CharlesTurner
Re: Top Loader rods and levers
« Reply #1 on: February 26, 2018, 08:16:13 PM »
The levers won't have the engineering numbers, but otherwise, the rest is acceptable.  I'm not sure what the finishes are, so they may need to be re-worked.
1967 eight barrel
  • Guest
« Reply #2 on: February 27, 2018, 02:47:03 AM »
Those offered by NPD and Branda are the same. I did have mine done phosphate. They're only an issue if you have a big block vehicle. ( Reverse rod)
        -Keith.
Bill Healey restores factory shifters as well as has some of the more scarce items. If you want Ford shift rods, Bill may have a set. He restored my Shelby's shifter.  No longer feels like a mop handle in a bucket.
        -Keith
http://stores.ebay.com/Vintage-Ford-Manual-Shifters
« Reply #3 on: February 27, 2018, 11:15:48 AM »
Bill's rebuilt shifter box looks good.
I'm not really to the transmission part of the restoration, but an ad popped up and here I am.
I may have to rethink this and instead of buying a used shifter box and having it rebuilt (or me doing it) just buy one already done. I don't think I can buy, replate and rebuild it for the cost of one already done.
« Reply #4 on: February 27, 2018, 11:38:37 AM »
Bill ,does excellent work.I have heard that he does not plate his parts anymore . Instead he paints them. That may not matter to you but thought I would mention it so that you have realistic expectations. If it does matter you may want to ask.
« Reply #5 on: February 27, 2018, 12:22:25 PM »
Jim Cowles also rebuilds/restores shifter parts and does the correct plating.
« Reply #6 on: February 27, 2018, 08:16:29 PM »
It's for the concours car, so yes, it matters.
That resolves that matter -- buy the one in the ad, tear it apart and plate it.
Buy the real rods.
Thanks for your input.
