Author Topic: 69 GT350 alternator ground wire bolt on point  (Read 599 times)
Offline Steve.chatman
« on: February 25, 2018, 04:25:55 PM »
Is the Alternotor ground bolted to the same place as the battery ground, on the side of the block? My assembly Manuel doesn't say.
Re: 69 GT350 alternator ground wire bolt on point
« Reply #1 on: February 25, 2018, 05:00:33 PM »
Believe it does attach using the same attachment point and hardware with the thick battery/ground cable that goes to the battery
« Reply #2 on: February 25, 2018, 06:29:39 PM »
To add to the conversation , the correct big block alternator harness ground eyelet is larger to accommodate the larger BB ground bolt diameter. The smallblock alternator harness ground eyelet on the other hand is smaller to fit the small block smaller diameter ground bolt.
« Reply #3 on: February 26, 2018, 01:27:30 AM »
Thanks guys!
