Author Topic: battery "L" bracket 69/70 boss 302  (Read 2597 times)
Offline 1970shelbyguy
« on: February 21, 2018, 12:38:06 PM »
 so what's the verdict ?  was there a cutoff when the L brackets came on stream - or were all  69/70 boss 2's supposed to have a bracket-- factory hit or miss install?   for a may/69  boss 302   thanks
1970 gt500  grabber blue  june/69     1970  boss 302  metuchen  dec/69
Re: battery "L" bracket 69/70 boss 302
« Reply #1 on: February 21, 2018, 03:37:54 PM »
The 69/70 Shelby's (a node to your screen name) got them regardless of battery option and the Boss 2's were made on the same line in Dearborn so most likely were the same. 70 B2 (not Shelby) had a different one because the change in holddown bracket.
Offline Crgjohnson
« Reply #2 on: February 21, 2018, 11:10:26 PM »
I was under the impression for 69/70 boss 302's if the apron had been drilled for the L bracket bolt then you installed one. If it was not then it did not come with one. Wasn't aware of a date cut off. Of course having a replaced apron all bets were off
Craig
70 BOSS 302(Dearborn 10/69) Medium Blue Metallic, CA emissions
70 BOSS 302(Dearborn 10/69) Calypso Coral, CA emissions
09 Shelby GT 500, factory stripe delete
MCA 69-71 concours BOSS gold card judge
Mustang restorer (hobby)
69 Cougar 3/69
« Reply #3 on: February 23, 2018, 09:10:51 AM »
The L battery bracket was  a 1970 mustang cougar part as the apron had a hump & punch out hole for installing it . 1970 shelbys were 69 built but changed serial #s over to 70 so they had the 69 type apron that never had the hump or punch out hole. 1970 battery aprons also had a dozb # by where the inside big hump was stamped into it behind battery for clearance on rad support for installing bid single headlight system changeover from 2 small headlight systems.  This is a common restoration mistake when replaceing rusted out battery aprons in 69 cars restorers replaced apron with the dozb style as that was fords service replacement part.
« Last Edit: February 23, 2018, 09:14:24 AM by specialed »
Offline Armond
  • Silver Level Subscriber
    • D'Agostini Restorations.com
« Reply #4 on: February 25, 2018, 03:09:38 AM »
I have been thru this, you've seen the yellow Boss 302 way back at a show in Washington Ed.   It is a late built 69, last week of production and has a 70 front inner fender and the hole is there and was never tapped with a screw.  So there is a transition time back then as parts were put into the bins!   Original and never changed out.
MCA#31064
« Reply #5 on: February 26, 2018, 02:51:24 AM »
Yes armond i had a  july 69 mach1 that had the battery hold down hole BUT did your car have the 70 dozb  # hump behind the battery  (for 2 headlight system) as 40 years ago i dont remember checking that then when i had the car so it maybe what  ford had on assembly line at the time dont know BUT years ago we had a low mile  last week 69  built b9 at shop & it had a 70 hood & doors on it so it maybe what dearborn had at the time on assembly line dont know.
« Reply #6 on: February 26, 2018, 01:48:50 PM »
Yes, we have a late built 1969 Dearborn Cougar with that 1970 apron. (hump and hole)
« Reply #7 on: February 26, 2018, 02:52:07 PM »
Guess we may need an open thread on very late 69 Dearborn cars and their oddities. ::)   Where we can record and compare apparent list of "70" items that made it into production early that year. We also have the marker light cars also.
Started one
http://www.concoursmustang.com/forum/index.php?topic=17633.new#new
« Last Edit: February 26, 2018, 06:02:16 PM by J_Speegle »
