Author Topic: 1970 Trunk Lock Clip  (Read 836 times)
Offline 1970 Snake
« on: February 20, 2018, 03:31:04 PM »
So I need to ask a silly question, does anyone have a picture of the factory installed spring horseshoe shaped clip that holds the trunk key lock in place.
I am not sure if it goes from the top or bottom and does the little hole in the middle secure to anything? Just want to get it right the first time on new paint.
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Re: 1970 Trunk Lock Clip
« Reply #1 on: February 20, 2018, 04:15:03 PM »
I believe that the little hole is for using a hook like tool for removal. The door lock cylinder clips should not have the hole.
Sorry, I do not know the position for mounting.
« Reply #2 on: February 20, 2018, 05:20:09 PM »
Very hard detail to find in a picture and even capture with all the stuff in the way.
Here is an example of a 70 Dearborn that appears to have been inserted from the passenger side (as if it were int he workers right hand moving towards their left) horizontally
« Reply #3 on: February 20, 2018, 06:09:02 PM »
In 69 on the East Coast they did it from the Left side.  Brian
Offline 1970 Snake
« Reply #4 on: February 21, 2018, 11:19:07 AM »
Thanks guys, so it looks like the clip is installed from the side not the top or bottom, good to know. And is probably installed either side depending on whether the installer was left handed or right handed. My car is 70 Dearborn so will install clip from the right side as indicated in Jeff's picture, although I am left handed, LOL.
« Reply #5 on: February 23, 2018, 08:50:30 AM »
every original 69-70-(dearborn anyway) car i have seen has clip installed from lh side like in brians photo because its closer distance to keyhole to install as the trunk latch support isnt in center its offset to the rh side more which makes installing from lh side easier.
