Author Topic: Drive Shaft Yokes: How to finish?  (Read 1630 times)
Offline evantugby
« on: February 19, 2018, 03:39:09 PM »
Gents,
My axle assembly is finished.  Give me some feedback please!
Question:  I'm inquiring about how to finish the two fixed yokes on my drive line and the slip yoke.  I also need to know the color of my pinion as well.
Thanks everyone!
Re: Drive Shaft Yokes: How to finish?
« Reply #1 on: February 19, 2018, 05:56:50 PM »
The driveshaft ends and yoke will be a slightly darkened metal appearance.  If I was restoring these, I would dunk them in phosphate for maybe 30s and then rub out with oil and steel wool, followed by cleaning the machined surfaces.
Was the rear tag mounted on the LH side like that?  Normally is on the other side.
« Reply #2 on: February 19, 2018, 05:57:36 PM »
Also, the axle ends should be natural with machined surfaces and heat-treated/darkened lug nut studs.
« Reply #3 on: February 19, 2018, 05:59:53 PM »
Agree with Charles. Basically a fresh cast look (not a freshly blasted look) with fresh machined surfaces returned to the end, trans and pinion yokes
Offline evantugby
« Reply #4 on: February 19, 2018, 06:59:14 PM »
thank you gentlemen.  I will correct!
Also I will move the tag to the other side too!  :)
Offline evantugby
« Reply #5 on: February 21, 2018, 09:34:30 PM »
Caspian, what are you guys doing to get machined surfaces on the ends of the axle? Which option is best? 1, 2, 3, 4 (left to right)
« Reply #6 on: February 21, 2018, 09:36:50 PM »
i like the #2 picture......just my 2 cents tonite.
« Last Edit: February 22, 2018, 09:16:57 AM by carlite65 »
« Reply #7 on: February 21, 2018, 09:43:15 PM »
i like a fresh #2.......just my 2 cents tonite.
Oh, I'm biting my tongue...and it hurts!
« Reply #8 on: February 21, 2018, 10:32:55 PM »
A number of those aren't going to work since they will brighten the surrounding metal. I've masked off the areas I don't want touched and used a fine paper with a backer doing it by hand. Did have a valve lapper (from back when you lapped the valves on things like Model A's and flat head V8's)  that I converted to a circular sander for the task on some items but haven't seen it foe a while
« Reply #9 on: February 22, 2018, 12:22:06 AM »
The roto-disc would work, but have to be super careful with it, otherwise you'll round the edges and create inconsistent lines in the metal as Jeff mentioned.  The wire brush might be best to get the metal clean, then do the phosphate treatment, followed by sandpaper on a sanding block or something else flat like a paint stick.
« Reply #10 on: February 22, 2018, 09:14:22 AM »
Boy! I read that before this comment and I am absolutely shocked! (because I didn't see this 1st time I read it!)
I'll hire a friend with a lathe to turn the shafts "as original". I have cleaned out the center holes in each hub-end in preparation and have removed all surface rust as mentioned above (after Rust-911 soak for a few days). Inside the hub area, still needs to be blasted, I am not getting a clean cast look in there. I had an air pocket when I soaked them so it is now inconsistant-looking.
« Last Edit: February 22, 2018, 09:20:56 AM by 67gtasanjose »
Offline evantugby
« Reply #11 on: February 23, 2018, 02:12:49 PM »
Thanks!
« Last Edit: February 23, 2018, 02:19:12 PM by evantugby »
