Second question: do you put them on before leaf springs are mounted to kar? they're in installed?
When in doubt copy what the factory did
They were installed to the springs before they were shipped to the car assembly plants
Is there a specific tool to put these leaf spring clamps on? How are you guys doing it?
Series of C clamps. Believe someone posted a series of pictures of the arrangement in a prior thread
Remember to protect surfaces from scratching the spring or clamp finishes.
1- Springs bolted together- held secure to a bench or some form of holder.
2- One C clamp to hold the clamp in place to the spring. If you center it or slightly off center towards the side with the hole in the strap
3- One C clamp to hold the sides into the spring.
4- Collapse/bend the end of the strap with the tab to the spring surface. If you off set the first C clamp then you can close it completely.
5- Remove the first c clamp if you haven't already and close the other end of the strap and engage the tab tightly
You done - remove everything and move on to the next one. Don't forget the insulator
