Author Topic: Trunk Lock Cylinder  (Read 613 times)
Offline ChrisV289
Trunk Lock Cylinder
« on: February 17, 2018, 08:30:52 PM »
Is there another trick to remove the trunk lock cylinder?  I've turned the key clockwise while pushing on the pin and it just does not want to seem to come out of the sleeve. Trying some penetrating oil to see if maybe that loosens it up...
2009 V6 Mustang Coupe
Offline rrenz
Re: Trunk Lock Cylinder
« Reply #1 on: February 17, 2018, 09:06:21 PM »
Could try removing the latch and giving it a shove from the back side. I know when I replaced mine I had the latch off but don’t recall the procedure. Just took a little screwing with
Ryan
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
Offline ChrisV289
« Reply #2 on: February 17, 2018, 09:14:49 PM »
Offline ChrisV289
« Reply #3 on: February 17, 2018, 09:26:15 PM »
Ok got it free. Next question, where does the small little gasket go? My original does not have one, and the website above does not mention it either
« Reply #4 on: February 17, 2018, 10:11:59 PM »
It slides over the lock cylinder and butts up to the end of the lock, closest to the key insert area.  I've seen them on originals.
« Reply #5 on: February 17, 2018, 11:30:55 PM »
Are you referring to the "O" ring? In the CJ pony how-to, pic 6, the "O" ring slides over the tumbler sleeve to fit between the rear piece, where the key is, to seal against the bezel. It's a tight fit.
Offline ChrisV289
« Reply #6 on: February 17, 2018, 11:55:17 PM »
Thanks, yes it was a very "tight" fit... ::)
