Author Topic: Finishing on these miscellaneous parts?  (Read 688 times)
Offline evantugby
« on: February 17, 2018, 04:40:01 PM »
Gentlemen, couple miscellaneous parts that I want to know how they need to be finished. Do any of them get paint or do any of them get something else?
Re: Finishing on these miscellaneous parts?
« Reply #1 on: February 17, 2018, 05:18:31 PM »
Watrpump plate is painted engine color with pump on engine, Thermostat housing painted engine blue (even on GT350),accelerator bracket P/O, Alternator adjusting arm is semi gloss black, clutch adjusting rod is bare steel and so is E brake arm.
« Reply #2 on: February 17, 2018, 05:30:53 PM »
FYI, previous discussion on parking brake part finishes for 65-66...
http://www.concoursmustang.com/forum/index.php?topic=16346.msg102247#msg102247
Offline evantugby
« Reply #3 on: February 17, 2018, 08:39:31 PM »
Bob, Caspian
Thank you very much!
I'll wait to paint the semi-gloss components with the same spray as the engine bay.
« Reply #4 on: February 17, 2018, 09:07:19 PM »
a tip....that alternator bracket is not the same s/g color as the block. remember that each black component was painted at it's point of manufacture of which each used a different gloss level. you don't want to have the same color (shade) of black on all black parts.
« Reply #5 on: February 17, 2018, 10:10:19 PM »
He has a '66... so should be ok.  Great advice though.
« Reply #6 on: February 17, 2018, 11:32:41 PM »
Most of those brackets are dipped in SG black. A different finish happens.
Offline evantugby
« Reply #7 on: February 18, 2018, 12:02:25 AM »
Great insight on the different shades of SG black!  Perhaps I should hit it with my rattle can so it looks a little different then when I hit the engine bay with SG black sprayed.
