Author Topic: '68 NJ Hood hinge spring orientation  (Read 536 times)
« on: February 11, 2018, 10:49:49 PM »
April '68 Metuchen car.  I'm seeing some hood hinge springs with the back hook installed from the inside and some from the outside.  Anyone ever noticed this or have an opinion if one way is correct or the other?
« Last Edit: February 12, 2018, 12:16:42 AM by J_Speegle »
Re: '68 NJ Hood hinge spring orientation
« Reply #1 on: February 11, 2018, 11:11:11 PM »
Found 4 cars so far with the RH side hinge having the spring installed from the outside on the back hook... weird.  If the back area can't be seen, it's easy to tell as the opening at the front of the spring will be to the top.
« Last Edit: February 12, 2018, 12:16:52 AM by J_Speegle »
« Reply #2 on: February 12, 2018, 01:01:30 AM »
The vast majority I found were drivers side down (front end of spring)  passenger side up.  Of course didn't look at restored cars or cars with a repaint
Same at San Jose as well. Haven't checked Dearborn.
« Reply #3 on: February 12, 2018, 02:17:58 PM »
Our 68 unrestored GT350 has the RH hinge hook facing down. I have no idea if it has ever been messed with.
