Author Topic: 67 - Radiator support  (Read 901 times)
Offline rocnhrse
« on: February 09, 2018, 02:19:01 PM »
67 S code GTA  San Jose  April 67
Is there a difference in sizes  between  any of the radiator  supports small block vs big block, I put in a NOS rad support  and it is too narrow  for the holes to line up on the 390 radiator shroud
« Last Edit: February 09, 2018, 02:54:09 PM by J_Speegle »
67 mustang  GTA  S code fastback  San Jose  April 67
Offline 196667Bob
Re: Radiator support
« Reply #1 on: February 09, 2018, 02:55:04 PM »
Master Parts Catalogs show only one radiator support, with no engine differentiation. Original Part # C7ZZ-16138-A, which was replaced by C7ZZ-16138-B in March of 1968.
Bob
MCA 04909
Re: 67 - Radiator support
« Reply #2 on: February 09, 2018, 02:58:20 PM »
There is an early and late version (change was during 67 production) of the radiator support but not one for each engine size but it didn't include a change in bolt hole locations
The radiator shroud on a big block does not attach to the radiator support and the radiator is not directly attached either but instead cradled between an upper and a paint of lower insulated mounts as discussed in another thread last week I believe
Picture of your issue and the parts your working with might help
Offline rocnhrse
« Reply #3 on: February 09, 2018, 03:13:36 PM »
My inexperience  got the best of me , didn't  do my research  got my rad shroud  today  and thought  it would  line up with holes in rad support ,there wasn't  one on the car when I got it might  be missing  some brackets
Offline 196667Bob
« Reply #4 on: February 09, 2018, 03:19:48 PM »
Jeff is of course correct in that the 390 Radiator did not mount into the holes on the radiator support as did 289 radiators.
I should have attached the following from the Body Assembly Manual.
Bob
MCA 04909
Offline rocnhrse
« Reply #5 on: February 09, 2018, 07:59:57 PM »
Thanks for information , great forum for restoration  problems
« Reply #6 on: February 09, 2018, 09:17:28 PM »
