Author Topic: Rubber transmission line connection to radiator for 65  (Read 2210 times)
Offline ChrisV289
Re: Rubber transmission line connection to radiator for 65
« Reply #15 on: May 21, 2018, 04:38:27 PM »
So just to confirm, a SJ car built 10/29/64 should have the tower clamps correct?  I was able to secure a set of 4 from American Mustang parts LLC
2009 V6 Mustang Coupe
« Reply #16 on: May 23, 2018, 02:58:27 PM »
I posted earlier a Feb '65 SJ example with crimp clamps, which is what your car should have.  The tower clamps came later.
Offline 66RavenGTCoupeAgain
« Reply #17 on: September 18, 2018, 10:05:09 PM »
Great info on here guys! Do we know if the barbed fittings on the radiator for the oil lines were painted with the radiator or not?
66 Metuchen NJ  GT Coupe
6T07A1612## Dec 65 Build
5R08C1496## Oct 64 Build
« Reply #18 on: September 18, 2018, 10:20:36 PM »
........... Do we know if the barbed fittings on the radiator for the oil lines were painted with the radiator or not?
Not certain but they may have been added after the radiator was received at the plant and after the radiator was painted. Would invite out other members more familiar with this detail to share
« Reply #19 on: September 18, 2018, 10:41:56 PM »
Yes that would be great, thanks. Chris???
« Reply #20 on: September 19, 2018, 12:23:17 AM »
Probably not. First, the fittings might get damaged in shipping so they were not installed. Second, they are shown in the Assembly Manual, which would indicate an assembly line step.
The 64 Chassis Assembly Manual shows either being used. That's before. More research required?
