Author Topic: 1967 10X 2.5" rear brake shoe hold down kit issues.  (Read 1015 times)
1967 eight barrel
  • Guest
« on: February 06, 2018, 12:07:35 AM »
When I re-assembled my rear brakes I noticed an issue with the hold down nails and retainers. I went back and tried three different kits, all with the same issues. I used the shorter pins with different spring retainers and was able to get them on. However, the current issue seems to be that the shoes are dragging a when they are released. Does anyone have a kit with the correct ones, or a kit manufacturer and number for ones that will work correctly. A total measurement on length of the correct hold down nail for the 10X2.5 shoes.
        -Keith
Re: 1967 10X 2.5" rear brake shoe hold down kit issues.
« Reply #1 on: February 06, 2018, 12:10:13 PM »
10 x 2-1/2 inch rear brakes? Do you have 2-1/2 inch backing plates?
Stock in 1967 was 1-3/4 inch.
« Reply #2 on: February 06, 2018, 12:50:52 PM »
He's either got an Econoline, station wagon or we take apart his online moniker and assume he has a 67 Shelby GT500 (Eight Barrel) with the larger rear brakes.
This all gets easier with a signature.
Offline 67350#1242
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
1967 eight barrel
  • Guest
« Reply #4 on: February 08, 2018, 10:58:43 PM »
It's a Shelby, 10X2.5 is what it came with. Yes.
1967 eight barrel
  • Guest
« Reply #5 on: February 08, 2018, 11:07:14 PM »
Keith,  Virginia mustang sells the correct length nails:
http://www.virginiaclassicmustang.com/Rear-Brake-Spring-Hold-Down-Pin-Set-for-25-inch-wide-shoes-65-66-GT350-and-others-Set-of-4-P482340.aspx
Kurt.
Kurt, Thank you for the heads up. All the old time parts houses have gone by the wayside and the chain stores are stocked with incompetent employees who lack the drive or interest to look up anything that requires the use of paper catalogs. I just ordered them.
        -Keith
« Last Edit: February 08, 2018, 11:11:05 PM by 1967 eight barrel »
1967 eight barrel
  • Guest
« Reply #6 on: February 08, 2018, 11:13:42 PM »
Perceptive you are indeed, Bill!
