Author Topic: Need an I6 6cyl Emergency Brake Shoe Bar PIN (Used Original)..  (Read 895 times)
Offline NEFaurora
« on: February 02, 2018, 12:25:01 AM »
Subject: Need an I6 6cyl Emergency Brake Shoe Bar PIN (Used Original)..  What I need here is the Small 1" inch long Steel Pin that secures the I6 Rear Emergency Brake bar to the Rear Brake shoe. It is usually secured with a small bendable "U" clip and friction washer.   I just need a good Used Original Rear PIN for the Rear Brakes...It holds the Emergency Brake cable bar to the Rear Brake shoe.
E-mail me at NEFaurora@aol.com if you have one or more that you can part with and what you want for it...
Thanks,  Tony K.   :o)
« Last Edit: February 02, 2018, 12:36:23 AM by NEFaurora »
MCA#70001
Offline NEFaurora
Re: Need an I6 6cyl Emergency Brake Shoe Bar PIN (Used Original)..
« Reply #1 on: February 02, 2018, 10:54:44 AM »
PS: I think the technical name for the pin(s) is the "Parking Brake Lever Pivot Pin" to be more correct....
Is the I6 pin the same as the V8 pin????
Got one??
:o)
Tony K.
MCA#70001
« Reply #2 on: February 02, 2018, 12:05:09 PM »
I might.  What part# do you have for the V8?  Also a pic of what you are looking for will help.
« Reply #3 on: February 02, 2018, 03:34:49 PM »
I had the MPC open . . .
If you are referring to the lever (which includes the pin).
it's a  "2A637-8 Lever Parking Brake Cable to Secondary Brake Shoe".
Looks like I6 and V8 are the same but they are different by drum sizes.
10" brakes are C9ZZ-2A637-A /  C9ZZ-2A638-A (RH/LH)
9" brakes are C9ZZ-2A637-B / C9ZZ-2A638-B (RH/LH)
A length of the item might help here.
Offline Andrew@MagMustangs
    • MagMustangs
« Reply #4 on: February 02, 2018, 07:36:03 PM »
The 10" brake lever on V8 cars did not have a separate pin like the 9" brake lever on 6 cylinder cars.
Offline NEFaurora
« Reply #5 on: February 03, 2018, 03:22:36 AM »
Here's a pic...!!  I found one in my garage...but I'd still like to find a source/supplier of these for the future...for I6 cars.
Sorry, but I forgot to measure it before I installed it today...
:o)
Tony K.
« Last Edit: February 03, 2018, 03:25:13 AM by NEFaurora »
MCA#70001
