Author Topic: '68 390 Distributor Vacuum Advance Units  (Read 2120 times)
Offline Oz390
« on: September 04, 2010, 08:52:57 PM »
Looking to put an original dizzy (C8OF-D) back on my '68 C6 S code.  Rebuilt and recurved to factory specs.  Trying to determine:
1. was the original a single or dual diaphragm? (I have one of each)
2. what would the pros/cons be for the two units?
« Last Edit: September 04, 2010, 11:31:08 PM by Oz390 »
8R03S : 76A I 2A 15M 72 5 U
Offline gtamustang
  • CPM
Re: '68 390 Distributor Vacuum Advance Units
« Reply #1 on: September 07, 2010, 02:56:20 PM »
Being a 72 DSO, I would expect to see a dual diaphram vacuum advance. The two different vacuum advances was to address better emissions through the operating temperatures of the motor (cool to normal operating temp). I really do see it as a pro/con, rather it is what
Ford did to improve the emissions of the motor.
Regards,
Pete Morgan
« Reply #2 on: September 08, 2010, 03:20:16 AM »
In 68 and 69 it is common to see a big block with manual transmission using a duel advance and the automatic with a single advance. Bob
