Author Topic: 66 Running Change Survey Thread - Disc Brake Master Cylinder  (Read 5647 times)
Re: 66 Running Change Survey Thread - Disc Brake Master Cylinder
« Reply #15 on: December 25, 2021, 01:30:12 AM »
Which style of MC would be expected on a mid-March San Jose car with serial number range of 175xxx?
Style without the adapter fittings
Offline Richdowl
« Reply #16 on: July 08, 2023, 10:31:42 AM »
Hello,
The previous owner replaced the original Bendix manual disc master cylinder with an OEM version on my 66 GT Coupe. I purchased an original that I'm planning on rebuilding. The finish for the original is natural cast Iron with a natural what appears to be a copper finish. My VIN is 6T07A101612 built on August 30th 1965 for the 66 model year at the Metuchen plant. The cylinder I purchased requires line adapters which I believe is correct for an early model 66. The question I have is do I keep the finish natural cast or should I paint it Semi-Gloss Black like the original Kelsey Hayes Proportioning Valve that's installed. The Distribution Block was also painted semi-gloss black but I removed the paint (should I have kept it semi-gloss black?). Does anyone know where I can get a copy of a diagram of the Bendix manual disc master cylinder?
Rich D.
1966 GT Coupe A code 4 speed
Built August 30th Metuchen, NJ Factory
VIN# 6T07A101612
« Reply #17 on: July 08, 2023, 11:04:58 AM »
Hello,
Rich D.
Only paint the master semi gloss black if you want it to look a typical assemblyline. The proportioning valve was painted semi gloss black on the GT350?s to identify them because they were adjusted for the 2 1/2 rear brake shoes.
Offline Richdowl
« Reply #18 on: July 08, 2023, 11:42:50 AM »
thanks for your quick reply :)
VIN# 6T07A101612
Offline Richdowl
« Reply #19 on: July 08, 2023, 11:44:12 AM »
What about the cap? Should I also paint it semi-gloss black to match the Cylinder?
VIN# 6T07A101612
« Reply #20 on: July 08, 2023, 02:58:06 PM »
The master cylinder with cap and retainers were painted as a unit semi-gloss black. There were caps/plugs installed at each brake line port leaving a shadow of bare steel ones the plugs were removed and the lines attached. Shadow was not as large as the whole machined surface there
« Reply #21 on: July 08, 2023, 04:45:58 PM »
To add about the plug witness lines Jeff mentioned , the fitting hole had a unpainted machined metal witness line circle's approximately the size of a a dime. That is a easy guide in case you do not have access to original rubber plugs. to use to make the circle.
« Reply #22 on: July 08, 2023, 04:57:27 PM »
Hello,
The previous owner replaced the original Bendix manual disc master cylinder with an OEM version on my 66 GT Coupe. I purchased an original that I'm planning on rebuilding. The finish for the original is natural cast Iron with a natural what appears to be a copper finish. My VIN is 6T07A101612 built on August 30th 1965 for the 66 model year at the Metuchen plant. The cylinder I purchased requires line adapters which I believe is correct for an early model 66.The question I have is do I keep the finish natural cast or should I paint it Semi-Gloss Black like the original Kelsey Hayes Proportioning Valve that's installed. The Distribution Block was also painted semi-gloss black but I removed the paint (should I have kept it semi-gloss black?). Does anyone know where I can get a copy of a diagram of the Bendix manual disc master cylinder?
Rich D.
After rereading the post I thought it best to clarify. The proportioning valve was semi gloss black on a GT350 for reasons I mentioned before. For those with regular Mustang the proportioning valve was typically painted a battleship gray. The distribution block was bare unpainted brass with a silver zinc attachment bracket.
« Last Edit: July 08, 2023, 05:01:34 PM by Bob Gaines »
