This may end up going into the old "educated guess" category.
A second choice , since the end goal is the correct paint marking, is to choose not to apply a mark until you have better info to base the choice on. Just a consideration.
If (and I emphasize "IF") the load rate of a 'similarly equipped fastback' is essentially the same, it would SEEM (and I emphasize the word "seem") that a
GTA coupe would likely have been issued the same rear spring as a GTA fastback. ......................
[/quote]
- So I guess that your (going by the MPCs) looking at -AV or -AU rear springs. Who's rating (625 lb) matches 4 other spring groups -S, -AF, -AJ, -AN, -AR,
A few thoughts
- First if those were the original springs we don't currently know if both had the same paint marks. Your original focus and purpose for the thread
- Comparing other cars and springs (in this example S code GT and GTA) with more documentation that we have for the small block GT and GTAs conflicts appear. The posted MPC pages and buildsheets show/suggest that the coupe and fastback built at the same time, equipped the same way would have received different rear springs.
For example all from about the same time period - After the date listed as the change date in the MPC
GT fastback - projected build date (PBD) of Dec 6 - One set of colors
GTA fastback - projected build date (PBD) of Jan 24 - Different set of colors
- Another twist. Looking at 67 small block GTs without AC I have two different paint markings but the changeover does not align with the MPC date unless the car was built two weeks earlier or its an example of the listed date being a soft date.
- Did anyone else notice - or maybe I'm missing it on the MPCs, where is the section listing 67 with improved suspension (as we're accepting represent GT and GTA) built before 10/26/66?
As mentioned before been here before and it becomes a circular exercise at points but maybe we can figure something out.
