Author Topic: 69 door glass bracket location  (Read 1888 times)
Offline Brock
« on: January 21, 2018, 03:30:35 PM »
Hi there I have a 1969 mach 1 and cant find any information where the brackets are glued on the door glass. If any body could give me these measurements for a fastback it would be appreciated. Thanks
« Last Edit: January 21, 2018, 05:39:56 PM by J_Speegle »
Re: 69 door glass bracket location
« Reply #1 on: January 21, 2018, 05:41:25 PM »
First - Welcome to the site. Hope you find help, encouragement and support in your Concours related endeavours. There is allot of information already here and finding it can be a challenge at times. Others have just started reading through the threads in the years they are interested in - discovering all kinds of new information and prompting new or additional questions. Don't overlook the Library section also.
Found this using the words "69 window bracket" in the search feature. Third "button" from the left in the tool bar above ;)
http://www.concoursmustang.com/forum/index.php?topic=13670.msg84555#msg84555
Is that what you were looking for?
« Last Edit: January 21, 2018, 05:45:23 PM by J_Speegle »
Offline Brock
« Reply #2 on: January 21, 2018, 06:26:27 PM »
Yes thank you i was  referred to a video on a cougar site and it said set brackets back 1" from ends of glass and said that was factory so just trying to clarify thanks
« Reply #3 on: January 21, 2018, 07:06:56 PM »
Given that the roller moves along that track there may have been some range where it was acceptable and it may be that different plants providing the glass had a couple of different jigs set up for this task that were different by that 1/4"
Believe that the measurements in the drawing were taken from an original front glass
Offline Brock
« Reply #4 on: January 21, 2018, 09:14:30 PM »
Thank you so much, on with the epoxy by your diagram. another question what kind of foam did they use between the body and chrome that holds the weatherstrip around top of door opening, thanks again for the diagram
« Reply #5 on: January 21, 2018, 10:13:58 PM »
Know we covered that subject in the first couple of years the site was open. Let me see if I can find the thread (or someone may beat me to it)
Guess your looking for what current product owner/builders are using as much as what was originally used for the thin (thickness) two sided adhesive black foam tape
Offline KevinK
« Reply #6 on: January 22, 2018, 01:56:52 AM »
I measured the window channels many years ago. I’m not sure if I have the windows handy. 1” or 1.25” sounds about right. I’m thinking more on the rear channel.
As for reglueinn, I cleaned out he channel enough to get a fair amount of glue in it. Back in the day, I used JB Weld. These days I would use DuPont Window Weld.
I’m pretty sure the coup and fastback windows were the same except for the vertical weatherstrip.
Lastly, I would sand the glass where the glue applies to the glass.
MCA #33800, Gold Card 3rd Gen
BAMA Member
Offline tobkob
« Reply #7 on: January 22, 2018, 10:47:39 AM »
Quote
+1 ...Back in 70-72 the windows were already coming loose and at the dealer where I worked we would sand the glass and use epoxy with pretty good results.
TOB
Offline 67350#1242
« Reply #8 on: January 22, 2018, 05:11:59 PM »
I've used Goop for gluing window glass in a couple of my everyday drivers with excellent results - the stuff really adheres to glass.
https://www.amazon.com/Amazing-GOOP-160012-Automotive-Adhesive/dp/B000CCID28
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
Offline Brock
« Reply #9 on: January 22, 2018, 09:12:10 PM »
Thanks guys really appreciate it and I thank anyone who can tell me the foam they used between body and chrome that holds weatherstripping around top of door opening
Offline KevinK
« Reply #10 on: January 23, 2018, 12:36:43 AM »
This may be what you are looking for. Not sure about the quality.
BAMA Member
« Reply #11 on: January 23, 2018, 01:24:12 AM »
