Author Topic: 1965/66 Mustang upper and lower control arms  (Read 4120 times)
Re: 1965/66 Mustang upper and lower control arms
« Reply #15 on: January 29, 2018, 07:39:16 PM »
What would be a good quality aftermarket upper and lower control arm to get if one had to.  I know the Rare parts one do not look factory, but they are made in the US i thing, not sure of the Scott drake ones?
Might check out Moog at the local parts store. IMHO they have generally been quality providers and the suppliers at time for Ford
« Reply #16 on: January 29, 2018, 10:40:11 PM »
Moog used to be the way to go but I am afraid that they have changed too. They will be a compromise also. You will be trading one compromise (Scott Drake )for another. Not a bolt on if you want a original look.
« Reply #17 on: January 29, 2018, 10:57:05 PM »
Agreed - took his "good quality" as a deviation from correct and original since that had clearly been addressed
« Reply #18 on: January 30, 2018, 12:31:29 AM »
Understood. Not really any easy button for this situation. Only different levels of compromise to choose from . The ones already mentioned are the main ones.
Offline Chris
« Reply #19 on: February 03, 2018, 02:39:46 PM »
This reproduction is available online, has correct waffle style rivets. Seems if you apply correct paint and boot it would serve as a pretty close example to use.
« Reply #20 on: February 03, 2018, 07:17:01 PM »
You will have to strip the black oxide coating off which is there to act as a rust inhibitor over the bare metal with something first. It is like a gun blueing process but is too dark for a correct bare metal look.  I have used a mild acid like wire wheel cleaner when dealing with service replacement parts that had the same finish . If you don't you will be wasting your time because they will not have the correct look even after dipping up to the ball joint in black paint.
Offline evantugby
« Reply #21 on: April 26, 2020, 12:02:06 AM »
BoB,
What product did you use for the "mild acid like wire wheel cleaner"?
Thank you!
« Reply #22 on: April 26, 2020, 02:55:27 PM »
BoB,
Thank you!
Eagle one chrome and wire wheel cleaner is what I use there are other wire wheel cleaners that use mild acid in their formula.
