Author Topic: Single speed wiper motor  (Read 683 times)
Offline CCP
« on: January 19, 2018, 12:24:40 PM »
Putting together a '66 and was wondering is there any way to test the wiper motor before I put it back in? It's a single speed motor. It has a terminal that accepts a 3 wire plug; black, orange and blue. There is also a brass terminal screwed to the body.
 Thanks for any help, Pete.
1969 Fairlane Cobra formal roof drag pack
1968 Shelby GT500KR
6F08A-GT,a/c,4-sp.,ps,build date 16A. DSO 24 Jacksonville
Offline NEFaurora
Re: Single speed wiper motor
« Reply #1 on: January 20, 2018, 12:33:20 AM »
Sure... Easy one.  Just put it up to a 12 Volt car battery using some probe wires... Done it plenty of times.  Don't forget to ground the unit to the negative side of the battery if there is a provision for it....like a 3rd wire for ground.
Obviously, This should go without saying..Check the Wiring diagram first so you know what wire is what for each color wire...
I don't know what each color wire is off hand without looking it up...but I can only guess that they are +positive, -negative and GND (Ground).  Usually a brass terminal is a GND Ground....so just check what all the wire colors are anyway..
:o)
Tony K.
« Last Edit: January 20, 2018, 12:39:32 AM by NEFaurora »
MCA#70001
Offline CCP
« Reply #2 on: January 22, 2018, 11:13:32 AM »
Thanks Tony! Tested it this morning; worked like a charm.
      Pete.
1968 Shelby GT500KR
