Author Topic: Are these upper control arms original?  (Read 1802 times)
Offline dsielke
« on: January 15, 2018, 12:53:00 PM »
I am starting to get together the parts and supplies to cleanup and restore the front suspension on my convertible. I now know the strut rod bushings and lower control arms are aftermarket so it put the uppers in question for me as well. They appear to be over sprayed with the same undercoating I have been cleaning off of the undercarriage, but it could just be road grime. I have owned the car for more than 20 years and never touched any of the suspension components... yet. :)
« Last Edit: January 15, 2018, 12:56:33 PM by dsielke »
6R09A138419: 1966 GT Fastback, Springtime Yellow
6R08T138429: 1966 Convertible, Tahoe Turquoise
Re: Are these upper control arms original?
« Reply #1 on: January 15, 2018, 01:14:12 PM »
clean them up some more around the ball joint area & repost please. need to see the rivits top & bottom.
« Reply #2 on: January 15, 2018, 01:28:35 PM »
Plus, on the underside, upper right hand corner towards the fender apron, there should be markings - a vendor logo and possibly a date code.
« Reply #3 on: January 15, 2018, 02:48:46 PM »
Agree with the others - going to take some cleaning to confirm details. We at least know that someone has been in there before given the front spring mount/saddle, cotter key and the shocks ::)
Offline dsielke
« Reply #4 on: January 15, 2018, 03:26:30 PM »
I replaced the shocks with motorcraft shocks when I did the engine compartment. If the saddle is aftermarket there is a good chance the upper arms are too.
« Reply #5 on: January 15, 2018, 03:37:33 PM »
Not saying the saddles are aftermarket (Ford sold a version like that- rubber insulator pads)  just they have been changed
Upper A arms appear to have rivets so they may be originals or service replacements but we need a better look and more details to evaluate
Offline dsielke
« Reply #6 on: January 15, 2018, 03:51:47 PM »
This is the best I could get without lifting the car and taking off the wheel, regrettably don’t have time for right now, sorry.
As is I can enjoy the car ( take it to cars and coffee and local shows ) so I am trying to get the parts found and collected before I take the front suspension completely apart. Just want to make sure I know what I need to still find before I take it apart so it’s down the least time possible. :)
« Reply #7 on: January 15, 2018, 05:05:36 PM »
imo the rivits look original. replacement ball joints are almost always bolted in.
Offline ChrisV289
« Reply #8 on: January 15, 2018, 06:14:36 PM »
Clean up around the area that faces out by the ball joint. Should be a two digit code.
2009 V6 Mustang Coupe
« Reply #9 on: January 16, 2018, 07:44:25 PM »
Looks like originals or old service replacements only based on the limited amount of things we can see.  Numbering on the boots might provide some important info as to time period
« Reply #10 on: January 16, 2018, 10:22:28 PM »
The uppers may be original Ford but they are a later 70's  service replacement type version. The lip on the boot indicates it is of the later style boot with a hard embedded ring that holds the boot in place. The assemblyline boot does not have that lip on the top side of the retaining ring but on the bottom side where the ring holds the boot securely in place.
