Author Topic: 1969 Dearborn Radio Suppressor Type and Location  (Read 2378 times)
Offline 69GTconvert
« on: January 15, 2018, 10:05:41 AM »
Disclaimer: I searched the site for this answer but couldn't find it.  I apologize in advance if this topic has already been covered.
My 1969 Mustang was built in Dearborn on April 8th and I have two questions:
1. I believe my Mustang would have come from the factory with the C6OA-18832-A radio suppressor but should it have the Fomoco script on it or Autolite?
2. Where should my radio suppressor be mounted?
Thanks.
George
Georgia
1969 Mustang GT Convertible
390 4V, Close Ratio 4 Speed
Royal Maroon - Black Standard Interior w/ High Back Seats
Re: 1969 Dearborn Radio Suppressor Type and Location
« Reply #1 on: January 15, 2018, 11:32:09 AM »
Thanks.
The 69 radio static suppressor is mounted on the regulator. You should get a set of the assemblyline manuals available from any of the larger Mustang parts vendors. one of the manuals in the set is the electrical version which has illustrations of where and how the radio static suppressor is installed.The one that was used in 69 was Autolite marked . FYI a excellent spot on reproduction of the suppressor is available from Virginia Mustang or NPD.
Offline 69GTconvert
« Reply #2 on: January 15, 2018, 12:57:19 PM »
Thanks for the info Bob!
George
Georgia
« Reply #3 on: January 15, 2018, 02:45:21 PM »
Sorry for the poor close ups. First two I ran across
Jan car
July car
Offline 69GTconvert
« Reply #4 on: January 15, 2018, 03:52:33 PM »
Thanks Jeff.
George
Georgia
« Reply #5 on: January 15, 2018, 04:11:40 PM »
The Shop Manuals have a lot of useful information.  Brian
Offline SCJSTU
« Reply #6 on: January 15, 2018, 06:03:29 PM »
a tip on the hood bonding strap which goes on lip of cowl..........bend in down some so it will not scratch the paint on hood.
1969 Shelby GT350 convertible  4spd-AC built 1-27-69
1967 Mustang S-Code 4-speed built Jan 1967 non therm
1956 Ford F100 Big Window 392 Hemi
1961 Falcon 2 Door Station Wagon 302V8
2004 Mach 1 Azure Blue
« Reply #7 on: January 15, 2018, 07:06:41 PM »
Great example showing how Ford wanted it and my pictures showing how they were installed in real lift.
Thanks Brian
Offline 69GTconvert
« Reply #8 on: January 16, 2018, 08:00:58 AM »
This is great. Thanks Brian.
George
Georgia
« Reply #9 on: January 16, 2018, 10:59:06 AM »
Brian,do not be confused between the Shop manuals which have a multitude of more generic information for a variety of Ford models and are invaluable for maintenance and  the assemblyline manuals which are specific to the Mustang and show assembly illustrations how the cars were put together along with the nuts,bolts,screws etc.used to do it.  Both sets are invaluable for any Mustang owner especially those that maintain their own vehilcle and want to make their car more assemblyline correct. It is a common misconception that both terms "shop manual " and  "assemblyline manuals"  are to discribe the same thing. They are 2 different sets of manuals with different information.
« Reply #10 on: January 16, 2018, 11:39:50 AM »
It will then not perform as intended, right?  A question: what is expected from a concours perspective?
« Reply #11 on: January 16, 2018, 12:14:56 PM »
it is expected to be mounted as intended. If it is bent back so as not to make contact and “ IF” a judge sees that then it is grounds for a deduction. Some may just write a mention others may choose a deduction.
Offline 1970 Snake
« Reply #12 on: January 20, 2018, 12:57:31 AM »
I seem to have misplaced my original hood bonding strip, does someone make a concours correct one??
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
« Reply #13 on: January 20, 2018, 03:56:00 AM »
I have only seen the earlier style reproduced. Call up West Coast Cougars .I would bet they had some to sell.
