Author Topic: 67 SJ Gaffer Tape Usage  (Read 3322 times)
« on: January 12, 2018, 11:33:58 PM »
After reading the fuel sender thread it occurred to me that Gaffer Tape is used in other locations, other than to hold down the fuel sender wire in the trunk.
On my 67 (Deluxe/Fastback) it is also used on the sills -- both sides -- to keep the wiring in place before the sill plates were installed.
Since we have to buy a roll of Gaffer anyway (2"?), do we know of other locations where this tape was used?
Re: 67 SJ Gaffer Tape Usage
« Reply #1 on: January 13, 2018, 12:19:47 AM »
Bill,
Have you got a set of the Mustang Assembly Manuals for your car? The use of tape is documented there.
« Reply #2 on: January 13, 2018, 01:41:18 AM »
Off the top of my head the only addition spot I can think and the only location where the tape will be seen would be over the taillight buckets bulb hole. Its thought that this was done at the supplier so that nothing would fall into the taillight light.
Not sure they were all 2" wide. Have measured the 67 applications
« Reply #3 on: January 13, 2018, 06:31:55 AM »
what kind of tape was used to hold the capillary tube on the A/C evaporator case?
« Reply #4 on: January 13, 2018, 08:50:37 AM »
Looks a lot like what was used at the door sill channel. A picture (below) of my unit before restoring has a shadow of what size/length was used there.
« Reply #5 on: January 13, 2018, 10:29:29 AM »
Gaffers tape was used under the door sill plates, it covers the hole at the base of the rear door pillars, it wrapped over the rear torque box pinch weld under the rear seat, it held down the fuel sender wiring in the trunk, it covered the tail light housing and hood signal housing holes, it was used on the evaporator case, it sealed the bottom of the instrument cluster, it held the steering column wiring to the column, it was used to cover holes under the door panel and was used to secure the console and AT wiring to the hump on the floor.
I probably missed some but as you can see it was used through out the car.
Marty
« Reply #6 on: January 13, 2018, 12:18:34 PM »
A word of caution, the tape used on my 66 San Jose Mustangs was (very) dark gray on the "sticky" side, the same color as the exposed side. Gaffer's tape may be white on the "sticky" side. I don't know what the color was on the "sticky" side for 67 on applications.
(Gaffer's tape is currently used to hold down the cabling of musical groups to the stage to keep people from getting tangled up.)
« Reply #7 on: January 13, 2018, 01:37:35 PM »
The same
« Reply #8 on: January 13, 2018, 01:39:09 PM »
Gaffers tape was used under the door sill plates, it covers the hole at the base of the rear door pillars, it wrapped over the rear torque box pinch weld under the rear seat, .............
Marty looked but could not find any San Jose 67's with the tape used under or near the back seat. Maybe we're thinking of two different places. And also never seen it used on the steering column on a San Jose 67. Is this in a visible location when the car is assembled?
This is the area I think your describing. Nothing evident here as there was in other years. Example is from really close to the OP's cars VIN.
« Last Edit: January 13, 2018, 07:21:43 PM by J_Speegle »
« Reply #9 on: January 13, 2018, 02:02:48 PM »
Bill,
Jim,
   I do not. That is probably a mistake -- more so as I'm usually a facts and data kind of guy.
I appreciate Marty's listing and see that I really need to get the manuals. For some reason I thought I could do without.
[on edit -- just ordered the 67 Assembly Manual Kit of 6 manuals]
« Last Edit: January 13, 2018, 02:14:49 PM by Bossbill »
« Reply #10 on: January 13, 2018, 07:52:50 PM »
For others here are some pictures of some fo the locations being mentioned for this specific application
From 7R03C1883xx
Trunk fuel sender wire application
7R01C1149xx
7R01S1974xx
7R02C1721xx Drivers side fell off. Tape location (green arrow)  tape (blue arrow)
7R03C1883xx
Taillight bulb hole covering
7R15988x
7R16808x
Hood turn indicator bulb cover
7R03C1883xx - Sorry for the blurry picture    ???
« Reply #11 on: January 13, 2018, 08:34:18 PM »
Here is a picture of our 68 HCS showing the gaffers tape on the rear torque box pinch weld. It was not used on fastbacks as you showed. I think it may have been used on convertibles too. I can not tell for sure in this picture.
BTW Jim the convertible picture shows the 67 gaffers tape to have a white back.
« Last Edit: January 13, 2018, 08:57:16 PM by ruppstang »
« Reply #12 on: January 13, 2018, 08:38:46 PM »
Will look through the 67 pictures to see if its there on 67 coupes and or convertibles Just hope I have enough stripped interior 67 San Jose coupes and convetible
« Last Edit: January 13, 2018, 08:41:05 PM by J_Speegle »
Offline rockhouse66
« Reply #13 on: January 14, 2018, 01:02:47 PM »
I seem to recall some tape was used around the air extractor area on my '66, so you might check that area on your '67 when you get the assembly manuals.
'66 GT FB
« Reply #14 on: January 14, 2018, 03:28:43 PM »
Checked real cars and didn't find them on 67's. At least on all the unrestored fastbacks that year and plant I found
I also recalled them from 66 - things change like in other areas where 66 San Jose did one thing and 67 didn't for some unknown reason
