I posted this over on the CJ forum, but thought I should include it here as well...
Awesome document, Marcus and Bob!
Noted a few typos, missing(?) info, and possibly some corrections to be made? Not criticizing, just trying to help - and gain a better understanding of these details.
Pg 6, #18 - "Distributor bracket" - I believe this should be Ignition Coil Bracket.
Pg 7, #21 - the picture on the right shows a D0ZF-AB carb, but the text beneath the picture describes the 1968 carb in the other pic. I think the '68 carb image may also have lost some of its text.
Pg 8, #22 - I have my original D0 motor mounts, if you want any pics.
Pg 8, #23 - no mention of the different versions of CJ oil pan (C8 and C9) and how they can be identified externally by the baffle spot welds? Also no mention of the windage tray and its variations?
Pg 9, #27 - Alternator fan blade change dates don't appear to match between the text on the images and in the description text.
Pg 10, #30 - wasn't there also a 1970 spacer version that had 4 holes, instead of the double "kidney bean" shapes?
Pg 11, #34c - Aren't BOTH brackets in the picture used for the alternator? The smog pump adjusting bracket is not pictured, but it is mentioned in the text.
Pg 11, #34e - text seems confusing to me... "...except those with AC that had an additional bracket as shown here above." I get the gist of the washer spacer, but what is this additional bracket that's mentioned?
Pg 13, #38 - this describes the 1969 starter cable mounting. Do you plan to add the 1970 starter cable mounting info?
That's as far as I've gotten ~ time for bed. Can't wait to finish reading the rest of it though! Wow!
