Author Topic: Front fender apron measurements/specs  (Read 2387 times)
Offline dlsimon212
« on: August 31, 2010, 02:57:10 AM »
I'm in the middle of replacing the front rad support & battery apron,,, but before I spot weld everything back together,, I'd like to know if everything measures out correctly, since it was damaged when I started & couldn't get good measurements.
I'm just wondering if there's a nice little picture out there, that show's some actual measurements to help line everything back up properly. I've got a ton of books,, but no info for this area.
Thanks, Doug
www.dougs65mustangrestoration.blogspot.com
Offline cobrajetchris
Re: Front fender apron measurements/specs
« Reply #1 on: August 31, 2010, 10:42:39 AM »
The FORD shop manual gives lower body measurements however I have never found any upper body measurements. The important thing is the structure is square. I would install your very front and back fender bolts and do a X measurement and that will tell you if your upper body is square. A tram measuring bar is the tool for this but a simple tape measure will work as long as there is no obstructions in the way. Another good tool to check the shock tower placement is correct is a one piece export brace, if it fits in the holes OK you know your shock towers are in place. If your car measures out good I would then install the hood and fenders to check fit. Remember to fit everyting first before you weld and it will save you a lot of grief later.
CHRIS KNOBBE
Offline Twilight65
  • Gold Level Subscriber
« Reply #2 on: August 31, 2010, 08:25:28 PM »
found this,
Dave
