Author Topic: Transmission Mount Markings?  (Read 795 times)
Offline ChrisV289
« on: January 10, 2018, 09:05:30 PM »
Mount appears to be original with a C4ZA part number. Found a yellow tab towards the back which I have seen before and then two orange stripes I guess on the top that would be hidden once installed. Anyone else see this before? I forgot to look under the transmission before dropping it off.
2009 V6 Mustang Coupe
Re: Transmission Mount Markings?
« Reply #1 on: January 11, 2018, 08:45:49 PM »
Have not seen the orange marks before on that type of mount
Offline Maksim27
« Reply #2 on: June 04, 2020, 04:11:03 AM »
Were the transmission mounts bare metal or painted semi gloss on San Jose Mustangs in early 1966.  How about the stud threads, were they phosphate or painted.  Was the stud plate bare metal or painted.
« Reply #3 on: June 04, 2020, 01:33:46 PM »
I have seen C4ZA originals a couple different ways. .Some were painted semigloss black up to but not including studs which look to be phosphate. The more typical way is rubber coating in the middle and out partially to the bolt holes the top a was bare steel or phosphate and the bottom in the center and studs are bare steel or phosphate .It is most likely a different mfg.thing IMO.
Offline Snydly289
« Reply #4 on: June 04, 2020, 02:55:36 PM »
I found a similar single orange stripe on my used service replacement C8ZA transmission mount on my 65 Kar. I also found blotchy white paint on the back flat face. This picture was a couple hours after evaporust.
65 K Code Fastback -5F09K325XXX, Oct. '64, Vintage Burg, Rally Pac, Arvinode Exh, lots '64 items
66 A Code GT Coupe -4 speed, bench Seat, P/S, A/C, Rally Pac, handling package, 8 track
66 A Code Fastback -Built 302, 66 S2MS Intake, WC T-5, 4-wheel Wilwoods, locking 9"
66 T Coupe
65 T Code Fastback
