Author Topic: Shackle Finish  (Read 3857 times)
Offline mustanging
Shackle Finish
« on: August 30, 2010, 07:10:55 PM »
I just order a set of rear shackles from Rare Parts for a 1970 Dearborn built Boss 302.  They came with a black e-coat type shiny finish with a phos & oiled serrated staked bolt.  What is the correct finish?
Offline Boss 302
Re: Shackle Finish
« Reply #1 on: December 08, 2010, 08:06:05 PM »
 Media blast them first, than phos. and oil them.
Jersey Boss
Re: Shackle Finish
« Reply #2 on: December 09, 2010, 01:01:00 AM »
You will need to strip the coating off (would not suggest blasting since that will change the surface texture unless you follow that up with a ceramic tumble)
We finish them as bare new steel (I like gun bluing brightened with steel wool but plenty of other paths to the same look) with weld blue at the stud end (where the one plate attaches to the two studs) and a heat treated look to the stud.
IMHO this best reproduces, for me, the two tone look of originals
Offline app01
Re: Shackle Finish
« Reply #3 on: December 31, 2012, 01:05:45 PM »
Same car: Dearborn May  70 built Boss 302
What should the finish be on the Shackle nuts?
Also what is the correct finish on the leaf spring front bolt and nut?
Currently own:
1962 Corvette 340hp
Previously Owned:
1970 Mach 1 (my 2nd car)
1989 GT
MCA #62598
www.PalmieriConcepts.com
Offline app01
Re: Shackle Finish
« Reply #4 on: January 21, 2013, 11:14:20 AM »
Just following up on this.
 Natural, Phosphate, red, other?
Currently own:
1962 Corvette 340hp
Previously Owned:
1989 GT
MCA #62598
Re: Shackle Finish
« Reply #5 on: January 21, 2013, 11:31:59 AM »
The shackle nuts were typically cadmium plated.
Front eye bolt would be natural darkened steel or phosphate works ok.  Big washer was zinc plated and lock nut would be cadmium.  There may have been some variance on these finishes based on supplier.
Offline app01
Re: Shackle Finish
« Reply #6 on: January 21, 2013, 02:53:47 PM »
Thank you Charles
Currently own:
1962 Corvette 340hp
Previously Owned:
1989 GT
MCA #62598
