Author Topic: Correct carb spacer for '66 SJ K code  (Read 1035 times)
Offline 21.04
« on: December 30, 2017, 07:04:04 PM »
I'm trying to find the correct spacer that would have been used on '66 SJ k code.  After a little research, I'm finding there were several versions that could have been used for 65-66 hi-pos.  Bob Mannel's book on small blocks indicate spacers with engineering numbers C4OE-9A589-A and C4OE-9A589-E could have been used.  There is a foot note on the version with engineering number ending (E) denoting this was used when there was a PCV valve.  The more common spacer seen for sale is the version with (A) ending engineer number.  When I look at the E and A versions side-by-side they are very similar.  However, the (E) version is machined flat on top and has no outline around the outer edge for the gasket as the A version does.  I understand both will be indistinguishable once installed but I'd like to identify the right part of anyone can help here.
-Matt
66 K code Conv GT red/red deluxe 4 spd
66 A code Conv Non-GT black/red deluxe 3 spd
66 Sprint Conv Unrestored Green/blk std 3 spd
Offline Morsel
Re: Correct carb spacer for '66 SJ K code
« Reply #1 on: December 31, 2017, 03:27:04 PM »
Did you ask on the hipo forum, I'm sure Fred would know the answer to this question.
good luck,
Jason
Offline 21.04
« Reply #2 on: December 31, 2017, 10:12:37 PM »
Thanks Jason.  Fred was my next stop if no one here knew for sure.
« Reply #3 on: December 31, 2017, 10:33:36 PM »
Might be the holidays (members out an about) that are slowing up the responses. Fair number of members have or have had K codes
Don't have any numbers but yours would ahve had the nipple for the PCV valve pointing to the firewall
Offline 21.04
« Reply #4 on: January 01, 2018, 02:08:08 PM »
Thanks Jeff!
