Author Topic: 69 Daytona Pinion Support  (Read 1652 times)
« on: December 30, 2017, 05:37:50 PM »
I am putting together a spare rear end and would like to be as correct as possible.  Need some help with the ' machined surface ' on the RF-C5AW-4668-C Daytona Pinion Support.  Does it paint, is primer color, or does it stay natural ? The rest of the body should be red primer ?  The Yoke body is semi-gloss black with the collar zinc oxide ?  Bolts are black oxide ?   Asking for corrections.  Thanks Brian
« Last Edit: December 30, 2017, 05:50:16 PM by Brian Conway »
Re: 69 Daytona Pinion Support
« Reply #1 on: December 30, 2017, 05:41:14 PM »
it is my opinion that machined surfaces always stay bare looking as if they were done yesterday. nice & fresh.
« Reply #2 on: December 30, 2017, 06:11:25 PM »
I have always seen the yoke shield a bare steel and not plated silver or painted silver as in the picture.
Offline 1969 Cale II
« Reply #3 on: December 30, 2017, 09:14:25 PM »
What I have seen is the part was painted the red oxide color then machined, so yes natural metal. The bolts would be I think phosphate/oil, dark gray/black color. The slinger is natural metal as is the yoke. Was yours painted black already/ Does it look like factory or somebodies handy work? If your lucky you might find some paint marks on the yoke, found some on my Cyclones yoke
Offline 7Lscjracer
« Reply #4 on: December 31, 2017, 01:12:51 AM »
Bought May '81, sold Sept '20
« Reply #5 on: December 31, 2017, 12:50:49 PM »
Great.  Appreciate the pictures.  Pinion body was painted separate from the N case and will be a shade different Red Primer. The yoke shield, pinion machined surface and probably the yoke itself are bare steel.  The snubber bracket is also left bare steel.  The bolts ( 5 ) are black zinc dichromate.  Observations;  the snubber bracket metal does not seem to be prone to rust/corrosion while the machined pinion surface and in particular the Shield are ?  Thanks for all the help.  Brian
« Last Edit: December 31, 2017, 12:54:55 PM by Brian Conway »
