Author Topic: 67-70 Trunk Wheel Well Lip Luggage Protector Strip  (Read 8429 times)
Re: 67-70 Trunk Wheel Well Lip Luggage Protector Strip
« Reply #15 on: January 04, 2018, 06:32:53 PM »
Parts cars are far and few in Europe and I do prefer original parts!
Then I guess you have a choice, ether give up and only think of ways you can't or think outside the box and think of ways to accomplish your goal . Example call West Coast Cougar or other Mustang or Cougar used parts vendors and buy some used windlace . Best of luck with what ever you decide.
Offline JohnRB
  • 0F03R120303
« Reply #16 on: January 05, 2018, 06:10:56 AM »
Bob
No worries. Another reader have already offered me some. Now I just need to find out how long it should be?
Offline JohnRB
  • 0F03R120303
« Reply #17 on: January 05, 2018, 07:10:36 AM »
Was there a special style used in Dearborn? Color and "grain"?
VIN# 0F03R120***
« Reply #18 on: January 05, 2018, 11:20:16 PM »
john nothing special most windlacing is the same & always black on ca. evap cars i seen .     Just checked a jan 69 built low mile met. car & original grey strip still glued in place.
« Reply #19 on: January 05, 2018, 11:43:49 PM »
Would be similar to what was used inside the cars in 70 not like the stuff used in the earlier years with the noticeable uniform pattern
Not sure if I have a close up of the later stuff. Maybe I'll check my Cougar
Offline JohnRB
  • 0F03R120303
« Reply #20 on: January 07, 2018, 11:35:18 AM »
Offline JohnRB
  • 0F03R120303
« Reply #21 on: January 07, 2018, 11:35:41 AM »
« Reply #22 on: January 08, 2018, 05:23:07 PM »
7R01C181xxx Black - 10.5"
7R02K18xxxx - Black - (only 2" was left)
0T02G160xxx - Missing, but yellow glue is 7.5".
I'll cleanup and use the C code parts car strip in the K car.
« Last Edit: July 11, 2018, 02:20:53 PM by Bossbill »
Offline Mike_B_SVT
« Reply #23 on: January 09, 2018, 12:46:46 AM »
I was going to ask if this applies to Cougar as well.  Mine is MIA (Oct 1969, Dearborn build, California evaporative emissions).
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
« Reply #24 on: January 09, 2018, 03:46:57 PM »
Since the rear wheel tubs are shaped differently from Mustangs I don't think they are needed. The Cougars have an edge on the inners that is formed to bend over the outer and not create the same blunt/sharp edge as in a Mustangs.   At least that is what I'm seeing in pictures of 68 & 70 Cougars
Offline edwardgt350
« Reply #25 on: January 11, 2018, 03:47:24 PM »
for 66 san jose car, were the black protectors glued on with yellow contact cement?
« Reply #26 on: January 11, 2018, 07:24:09 PM »
Though that falls outside this thread - yes
Offline cob428
« Reply #27 on: July 07, 2018, 06:51:55 PM »
9T02M Black 10 5/8
9F02R Gray 11 1/8
Concourse Wantabe
69 GT 500 Built Dearborn 06/69
A/C, Auto,
69 Mach 1 Metuchen 11/68
A/C, Auto 351 W
2009 Supersnake
« Reply #28 on: July 13, 2018, 12:34:31 PM »
those lenghts are what i see on coupe & verts as fastback 8 1/2''   are u sure the Met car had a black from factory original to the car?
