Author Topic: 1970 Trunk Pinch Weld Cover  (Read 2279 times)
Offline 1970 Snake
« on: December 28, 2017, 08:04:33 PM »
Does anyone know what material is used to cover the trunk wheel tub pinch weld and where to get the material.
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Offline 7Lscjracer
Re: 1970 Trunk Pinch Weld Cover
« Reply #1 on: December 28, 2017, 11:07:10 PM »
http://www.concoursmustang.com/forum/index.php?topic=5256.0
Hopefully the black one is right for your car since all the suppliers carry them.
I would think the repros have the little V notch out as original, but easy enough to do yourself if need be.
« Last Edit: December 28, 2017, 11:26:46 PM by 7Lscjracer »
Bought May '81, sold Sept '20
Offline tobkob
« Reply #2 on: December 28, 2017, 11:31:38 PM »
If you need gray luggage protector you might want to check this out.
http://saacforum.com/index.php?topic=42529.0
TOB
Offline 1970 Snake
« Reply #3 on: December 29, 2017, 01:34:05 AM »
Thanks guys, mine is a Dearborn car, and assume grey is needed.
Additionally to that end where do I get it and also the white 6" long snap tie for the fuel sending wire?
« Reply #4 on: December 29, 2017, 05:22:47 AM »
Doing a survey right now of my pictures for the producers. Most likely yours was the gray version
An opaque zip tie of the right size will likely take care fo that for you. Original unused ones are not easy to find when you need one
Offline 7Lscjracer
« Reply #5 on: December 29, 2017, 05:47:24 PM »
Is this the one on page 175 part numbers B-10981 or 351053-S?
The thing to do is check the Ford number against that shown for the zip tie in your assembly manual.
If it's not an exact match there's no point, just use a generic one like Jeff suggested.
http://amkproducts.com/Catalog_PDF/165-176.pdf
« Reply #6 on: December 29, 2017, 08:21:50 PM »
B-10981 is the closest IMHO to the originals from what I'm measuring  if that helps
Its the same style (releasable) also
« Reply #7 on: January 05, 2018, 10:02:24 AM »
that white ty strap amk has is the correct panduit type as ford used them in several places & if u want an original grey strip we have a couple left on our ebay store  or u can wait as the new correct repo grey strip will be on the market shortly.
Offline 1970 Snake
« Reply #8 on: January 06, 2018, 09:48:41 AM »
I would like to get a new grey strip, can you please advise when and how to get it.
I have ordered the white/clear snap ties from AMK.
« Reply #9 on: January 06, 2018, 05:34:38 PM »
I would like to get a new grey strip, can you please advise when and how to get it....
I suggest that you drop Ed a PM. Just click on "specialed" next to his post then choose "Send PM" under his screen name on the left side of the window
To others who might find this thread in a search about the subject here is another thread that might be helpful
http://www.concoursmustang.com/forum/index.php?topic=17161.0
« Last Edit: January 06, 2018, 05:36:42 PM by J_Speegle »
Offline aussie trev
« Reply #10 on: January 12, 2018, 01:49:58 AM »
Hi all. my first post here ,been a member for a while.  My dearborn (oct 69 built) 70 boss 302 has 1 black  cover on drivers side ,should there be one on the pass side been covered by the spare space saver. thanks trev.
« Reply #11 on: January 12, 2018, 01:51:08 AM »
........................My dearborn (oct 69 built) 70 boss 302 has 1 black  cover on drivers side ,should there be one on the pass side been covered by the spare space saver. thanks trev.
No
Offline aussie trev
« Reply #12 on: January 12, 2018, 02:01:45 AM »
ok thanks
