Author Topic: solenoid  (Read 5418 times)
Offline preaction
Re: solenoid
« Reply #15 on: April 25, 2018, 02:36:26 PM »
How many amp rating does a power top require ?  A/C is 25 IIRC.
Re: solenoid
« Reply #16 on: April 25, 2018, 06:10:27 PM »
Used circuit breakers for 1969-73 convertibles are 20 AMP.
Offline 66SevenLitre
Re: solenoid
« Reply #17 on: April 26, 2018, 08:09:28 PM »
Take note how different each of these are to one another and always check against a known original before you choose ;)
Jeff - agree.  Question for you and the board, most of the 1960s Ford breakers I've seen have the Tung Sol stamping.  A few have T/S in a circle.  I've seen Wagner breakers but in `70s applications.  Have you seen anything other than Tung Sol for the 1960s Ford breakers?  Just curious.
By the way, here is an Ebay listing for a NOS C4DZ-14526-C relay.  A bit hard to read with the lighting, but it does say Tung Sol.
https://www.ebay.com/itm/NOS-1964-72-FORD-MERCURY-20-AMP-CIRCUIT-BREAKER-Galaxie-Torino-Comet-Full-size/122925273920?epid=17007641358&hash=item1c9eead340:g:kqMAAOSw1zhaZBc-&vxp=mtr
Re: solenoid
« Reply #18 on: May 04, 2018, 09:14:45 AM »
Has anybody documented that convertibles with the power top option used the HD yellow c8tf voltage regulator like the factory A/C cars used?
Re: solenoid
« Reply #19 on: May 05, 2018, 12:25:30 AM »
I checked the 68 Mustang Electrical Assembly Manual and it list C7AF-11450-A1 or A2 as the only solenoid. The power top drawing does not have another one listed.
Re: solenoid
« Reply #20 on: May 05, 2018, 12:43:23 AM »
Maybe figure it another way. If the convertible in question (assume a 69/70 since you are asking) got the group 27 battery wouldn't that automatically come with the 55 amp alternator ? If it got the 55 amp alternator the yellow marked C8TF voltage regulator would be the mating regulator. Wouldn't it?
