Author Topic: FMX tail shaft  (Read 2646 times)
Offline 1969 Cale II
FMX tail shaft
« on: December 20, 2017, 07:56:39 PM »
What color would a tailshaft from a 72 FMX be? My 69 is an alloy of some sort,medium gray. Not cast iron and not aluminum. Somebody posted a pic that somebody else thought look super, mine is all natural parts with no comment. His tailsahaft is aluminum color. He used cast gray on iron center, just wondering if other years had different metals?
Re: FMX tail shaft
« Reply #1 on: December 20, 2017, 11:17:34 PM »
Your going to have to let the metal be your guide since the main pieces were typically uncoated and unpainted. Yes different years and even models (examples would be 68 where 390 C6 tailshaft housings were aluminum while the CJ C6 has a cast steel housing)   Sorry don't have any pictures that cover that detail in 71-3
Here is what the FMX looks like that I did for the 69 Shelby I did a few years back
Bellhousing and tailshaft housing were finished as bare metal with a few stained area blended in lightly with paint so you could not tell. Main cast steel body was coated thinly with the ceramic natural paint a number of others have used for years on case iron four speeds. Its a little shinny from being fresh and under bright shop lights. Not noticeable and dies down once under the car and installed
Bare steel spacer between the main case and the tailshaft housing , some hardened attaching bolts, zinc speedo cable retainer with dichromated retaining bolt...
« Last Edit: December 20, 2017, 11:22:14 PM by J_Speegle »
Re: FMX tail shaft
« Reply #2 on: December 21, 2017, 08:47:32 AM »
Thanks, interesting that the tailshafts would be a different material in the same year. I would post a photo but don't know how.
Re: FMX tail shaft
« Reply #3 on: December 21, 2017, 02:27:53 PM »
There are a number of different ways to post pictures depending on where your going to store them.  Use the search feature and that should provide some help
Re: FMX tail shaft
« Reply #4 on: December 21, 2017, 11:03:30 PM »
Concours job on my FMX
Re: FMX tail shaft
« Reply #5 on: December 22, 2017, 08:21:57 AM »
I wonder why the tailshafts are made of different materials? Mustang vs Fairlane
Re: FMX tail shaft
« Reply #6 on: December 29, 2017, 03:21:54 PM »
Only guess I can make is something related to the weight of the intended vehicle and torque on the mount to transmission point.
Offline TLea
Re: FMX tail shaft
« Reply #7 on: January 03, 2018, 07:21:43 PM »
Jeff, what color stripe on your FMX modulator?
Re: FMX tail shaft
« Reply #8 on: January 03, 2018, 08:19:31 PM »
We found a robin's egg blue - very similar to the dip stick tube
