Author Topic: Convertible windshield moldings, clip locations?  (Read 1414 times)
« on: December 19, 2017, 11:15:48 PM »
Has anyone run into issues on a '68 with the convertible stainless molding clips not lining up with the clips on the windshield surround?  I'm working on a '68 Shelby and on the driver side, the top and bottom clips on the car are not lining up with the clips on the molding.  On the passenger side, just the top one didn't line up... which I can live with.  I noticed in the assembly manual that the side moldings call for a C7ZB number, so suppose there was a change from 65-66 to 67-68?
There were no issues with the windshield area on this car, the original rivets were all in place and correct clips installed before the glass went in.
Probably something I would have run into before, but maybe got lucky and did not have a car that had mixed-n-matched moldings?
Car in question is a late April '68 Metuchen build.
Re: Convertible windshield moldings, clip locations?
« Reply #1 on: December 19, 2017, 11:40:09 PM »
Pic
Yellow arrows are clips on the windshield frame, at original rivet locations.  Red rectangles on molding are location of the clips/sliders
« Reply #2 on: December 20, 2017, 12:27:57 AM »
I think I have a set of moldings around. I am not sure if there are any part numbers but I can measure the clip locations.
I will look for then tomorrow.
Marty
« Reply #3 on: December 20, 2017, 12:32:26 AM »
Thanks.  There are no part numbers on these.
Been looking around at pics and not seeing any differences in the clip locations (on the moldings).
Just checked... the actual build date of the car was April 22, 1968.... a Monday  :-\
« Reply #4 on: December 20, 2017, 08:41:16 AM »
It may be easier to move the clips but I am not sure if you can with out pulling the widshield :'(
Marty
Offline Coralsnake
« Reply #5 on: December 20, 2017, 12:12:27 PM »
Charles, I think on the molding side , the clips float and can be adjusted? or are they tack welded? cant tell from you picture
Offline gtamustang
  • CPM
« Reply #6 on: December 20, 2017, 02:29:36 PM »
I concur with Pete (aka coralshake), the clips on the stainless move.
Regards,
Pete Morgan
« Reply #7 on: December 20, 2017, 08:04:16 PM »
I located mine and they are as Pete said  adjustable.
« Reply #8 on: December 20, 2017, 08:49:50 PM »
It appears one of our resident experts failed a knowledge test! :P   Back to the books there Charles and hope you pass the next test.  *G*
Just kidding, of course.  Let's see the end result when you got it installed.
« Reply #9 on: December 21, 2017, 12:26:08 AM »
I disagree on the moving, there are 3 notched out areas on the moldings where the V shaped clips fit into.  If they are moved out into other areas, they'll be more prone to slipping off.
Additional pics, showing more clearly how screwed up it is.  Also pics showing the notches and one of the V clips.  The blue tape on the windshield has arrows that point to where the rivet studs are located.
« Last Edit: December 21, 2017, 01:39:16 AM by caspian65 »
« Reply #10 on: December 21, 2017, 09:16:04 AM »
Wow that is way off! I have seen miss placed studs before but they were on coupes or fastbacks so it did not matter that much.The molding that I have has clip locations just like yours.
 I do not see any other way to properly fix it with out relocating the clips on the body. I have used the 65 clip screws to fix broken or missing studs.
 Originally there must have been enough sealant to keep it in place.
« Last Edit: December 21, 2017, 09:18:32 AM by ruppstang »
« Reply #11 on: December 21, 2017, 12:33:12 PM »
Yes, think I’m going to have to install screw clips.  :-\
« Reply #12 on: December 21, 2017, 03:16:24 PM »
Is it possible that the convertible side moldings are different during the 4.5 years and what you have doesn't match the car?  Did this molding come off of this car?  I take it this molding doesn't have a part number on it.
« Reply #13 on: December 21, 2017, 09:40:07 PM »
That was what I originally asked... but having looked through a bunch of originals, I don't believe the clip location changed.  I know at least one of the moldings is the original as it still had a little orange paint over-spray on the back edge from when the car was painted orange in the early 70's.
« Reply #14 on: December 21, 2017, 09:42:47 PM »
If it was originally on the car, how was it attached, given the location of the clips and the rivet locations?  When you cleaned up the molding, were the clips where they are now?  Is there any chance the left and right moldings are swapped, or are the rivet locations the same left and right?
