Author Topic: Choke Tube Assembly  (Read 2374 times)
Offline Sunlitgold68
Choke Tube Assembly
« on: August 27, 2009, 11:57:21 PM »
For 1968 289 engine, if changing from an Autolite 2100 to an Autolite 4100 will the choke tube assembly hook up the same.
8T01C204XXX
Built May 14th, 1968
Offline Murf
Re: Choke Tube Assembly
« Reply #1 on: August 28, 2009, 12:58:13 AM »
I think that the choke tube is the same on the 2100 and the 4100.  Normally a 68 4 BBL is found on a 302 and is a 4300 carb, which use a different choke tube.  When using a 4100 the choke thermostat housing is in the same location as a 2100.
John Murphy
