Author Topic: Searching for my 71 429 SCJ mach 1's original engine block serial no. 1F186287  (Read 812 times)
Offline wozzel
Hi all,
Im pretty sure this is going to be a long shot but will put it out there anyway. Im searching for my 71 mach 1 429 SCJ's original engine block, the serial number on the block should be 1F186287.
Cheers,
Aaron.
I think it has been re-cast into a Mopar engine in or around 1981, and re-cast yet again into a few hundred brake drums and rotors before 1990. By now, it most likely is used as slag steel.  ;D
OK, seriously, I hope you do find that needle in a haystack...most likely, whenever it was removed, it had issues (not limited to being a gas-guzzler) in any event, it most likely would have been disposed of into recycling.
