Author Topic: 1970 9" rear axle housing yellow paint  (Read 3726 times)
Offline 1970 Snake
Re: 1970 9" rear axle housing yellow paint
« Reply #15 on: December 19, 2017, 03:03:23 PM »
Much appreciated Jeff, just to be clear you are saying the tag would follow the yellow flange marking to the PS of the axle??
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
« Reply #16 on: December 19, 2017, 04:45:56 PM »
No I'm suggesting that the two are likely unrelated and likely applied by different workers at the rear end plant distant from one another in that plant. If your going to use the ID paper slip place it where it has been documented many times so that you have at least a reason if someone asks or if someone chooses to copy
Offline JohnB
  • 0F03R120303
« Reply #17 on: February 16, 2022, 11:11:32 AM »
https://www.motortrend.com/how-to/1703-detailing-and-restoring-the-mustang-9-inch-rear-axle/
Not all pics are availble. Anyone downloaded it with all pics?
