Assumed it was original as the major components of the car are....date stamps, part#'s, etc. It was totally disassembled for repaint, so I guess it's possible the wrong kick down assembly was re-installed...any way, if the build date of the car suggests it should definitely have the other(1966) kick down linkage, I will replace it. I have the '66 service manual, so I'm not going to buy the '65 just to read how to adjust this one, '65 assembly.
Thanks...
If consensus confirms you have the wrong setup, the setup you have would be more than likely more valuable than the setup you need.
In any event, the adjustment process isn't very complicated IMHO. I cannot recall ever using the service manual to adjust these before but I would say having the Service Manual procedure is a good "starting point" to getting the adjustment fine-tuned. Usually, this setting is adjusted to the driver's desire, if a person likes a quicker kick-down for more of a perfomance setting, the adjustment is tightened in increments to get the desired engine RPM up-shift/down-shift points. These adjustments are confirmed or rejected with road testing. Other's (a.k.a. the grandpa setting), like it dialed back, which runs the engine at slower RPM shifting/downshift points.
Now, in a situation of not having the correct service manual procedure, I have found on these older cars, any make or model, I usually have used this tried & proven procedure (for a starting point):
ENGINE OFF, begin with a correctly adjusted throttle pedal adjustment, confirmed by holding the the gas pedal down to the floor (inside the car, have somebody hold the pedal pressed to the floor), while holding the throttle down, go under the hood, air cleaner assembly off the vehicle, confirm the throttle plates of the carb are fully open. Now, with the throttle still on the floor (ENGINE IS STILL OFF obviously) adjust the kick-down ALMOST to the MAX setting, allowing a little slack for engine torque, motor mount stretching etc. (there is a reason these 66-68 "cable version" was eventually scrapped)...this should get you to a good "beginning point", now move to fine-tune setting and confirming YOU like it through road testing. If it feels good, kicks down at YOUR desired RPM's there you go. If it is sluggish on down-shifts, tighten the cable (linkage). If the RPM's seem too high before shifting, loosen the adjustment.
