That Mobil 1 attachment is a good chart. The 15w-50 says right there it is for flat tappets. When our classic Mustangs were being engineered and built the API specification for zinc and phosphorous was 1,000 to 1,200 ppm for API SC to SE. The SF rating in 1980 raised it to 1,400. The present ppm is in the 600 to 800 range to protect catalysts to 150,000 miles. However there are exceptions. The euro spec oils for MB, VW and Porsche still have 1,000+ ppm as do the diesel oils and the Mobil 115w-50. We have all heard and read too many horror stories about flat tappets to risk any oil less than 1,000 ppm. Why take a chance when there are really good modern oils out there with 1000+ ppm? I decided that I would only use API certified oils from manufacturers that actually have the expertise to provide lubricants to the manufacturers, Ford, GM, FCA, the Euros, etc. For newly rebuilt engines I have used synthetics and have not had a leaking problem. Mobil 1 15w-50, 5w-40 for instance. For original engines I have stuck with conventional oils, not wanting to risk leaks. Maybe it will leak, maybe it won't, but why go through the hassle? So my choice there has been Shell Rotella T-4 10w-30. It is also available as 15w-40. Both have 1100 ppm. Also, I have not used it, but Castrol Edge Synthetic in the 5w-50 weight only, says specially it is for classic and older vehicles. It has 1250 ppm of zinc & phosphorous.
