Author Topic: Difference 69/70 Drum brake Spindles  (Read 1264 times)
Offline Jerry
« on: August 23, 2010, 04:45:19 PM »
Hi guys
Beside date codes of course what are the differences in those spindles
comparing the 69 to the 70??? Is there something different or are they the
same? Material different?? Only drum brake spindles i´m talking about.
Thanks Jerry
Offline Scott302
Re: Difference 69/70 Drum brake Spindles
« Reply #1 on: August 24, 2010, 06:42:36 PM »
The 70 spindle is thicker.  It'll use a 13/16"-20 nut versus 3/4"-16.  The bearings and races are also different to match the thicker material.  The tie rod hole is also larger diameter.
Then there is also the 65-69 replacement spindle that used the larger bearing sizes but had the smaller tie rod hole.
Scott
Scott Halseth
Ford Product Manager
National Parts Depot
MCA#01776
Offline Jerry
« Reply #2 on: August 25, 2010, 04:04:19 PM »
Thanks Scott
That is all i wanted to know great!!! ;o)
Bye Jerry
