Author Topic: original style '66 289 Autolite 4100 gasket  (Read 1147 times)
Offline socalgt
« on: November 27, 2017, 07:43:26 PM »
I'm looking for a picture of the original style gasket between the Autolite 4100 and the carb spacer.
Re: original style '66 289 Autolite 4100 gasket
« Reply #1 on: November 27, 2017, 08:16:21 PM »
I thought I posted some pictures. The black in the center is gaffers tape used to assist the camera focus. Theses are new and uses, carb to spacer, spacer to manifold.
Offline socalgt
« Reply #2 on: November 28, 2017, 09:58:37 AM »
I'm trying to solve a vacuum leak.  I can't find one that has the  4 holes in it, only with the whole center cutout, as in gask spacer #3.  To be clear, the one with the four hole cutout goes between the carb and the spacer?
« Last Edit: November 28, 2017, 10:00:53 AM by socalgt »
« Reply #3 on: November 28, 2017, 12:53:42 PM »
Yes.
The local Mustang shop stocks the bottom gasket. It's a FlePro for a mid 70's 460. The NPD supplied, Walker rebuild kit does not have one. I believe this was addressed in a previous posting.
« Reply #4 on: December 03, 2017, 09:18:08 PM »
I know the topic is '66, but thought I would share a pic of a new car intake take-off part.  I bought this with the spacer and carb.  The spacer was metallic reinforced, not all fiber.  I believe the intake was dated somewhere around May '65.  I used the gaskets on the K code convertible car I restored.
Offline markb0729
  • South Jersey
« Reply #5 on: December 04, 2017, 03:14:17 AM »
The four hole gasket is what you want if you are looking for an original style gasket for an A-code Mustang.  Good luck finding an OEM part, I couldn't find one.  The closest after market gasket you will find is the FelPro, part number 60059 which is sold at auto parts stores and Mustang parts suppliers such as NPD.  It fits like crap but many have successfully used it (see second picture).  I decided to make my own with gasket material purchased at Pep Boys (see third picture).  Be aware that if the spacer or carb base is warped, you may have sealing issues.  Just to be sure, I sanded my carb spacer on both sides using 400 grit Emory cloth taped to a mirror (you can use glass too) to make sure it was perfectly flat (see fourth picture).  I used the carb spacer as a template and cut the gasket with an X-Acto knife then sanded the edges with 150 and 400 grit sandpaper to clean up the edges and holes.  Worked well for me.
Edit: I used the four hole gasket for carb to spacer and spacer to manifold.
« Last Edit: December 04, 2017, 03:28:23 AM by markb0729 »
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
