« Reply #4 on: November 26, 2017, 11:09:47 PM »
Got some time today to look at the 4100 leaking gas via the secondaries. I replaced the gasket underneath the rear booster and the small round gasket under the retaining screw. I noticed that when I took the booster off the cylindrical holes where the tubes of the booster go down in, were full to the top with gas.? After replacing the gaskets I ran the car for a bit and noticed wetness on the boosters still. When I had the top of the carb off I verified the rear float is set correctly. Now that I am still seeing wetness I’m guessing the needle is not fully sealing the valve which must be letting gas come through the boosters and drip?? I have another needle and valve so I will replace that next and see if it seats, stopping the gas from dripping down the booster. Any other ideas?.
Logged
