Author Topic: 1969 S Code 4 Speed Carb  (Read 2508 times)
Offline mason1958
« on: November 23, 2017, 01:07:04 PM »
I'm looking for a correct carburetor for a 1969 390 Mustang. I'm not sure of the part number maybe C8OF-9510-C list 3795-1 ? My car was built 3-17-69. If anyone has one or know of one please email me at mason1958@carolina.rr.com
« Last Edit: November 23, 2017, 01:29:32 PM by mason1958 »
Offline rockhouse66
Re: 1969 S Code 4 Speed Carb
« Reply #1 on: November 23, 2017, 01:24:37 PM »
I believe this is an Autolite 4300 if that helps anyone looking through their pile of old carbs looking for this number.
'66 GT FB
Offline mason1958
« Reply #2 on: November 23, 2017, 01:29:52 PM »
Thanks Jim for the info. Mason
« Reply #3 on: November 23, 2017, 02:04:36 PM »
You could look in the library under "Year-Engine-Carburetor List".
« Reply #4 on: November 23, 2017, 02:38:20 PM »
+1
Going to be a challenge to find one but good luck hope you do. IF you get into a pinch I possible have a NOS one (from a slightly different application)  that could fill in until you find the correct one. Just depends if this is holding up a restoration or you can wait.  Have a couple of friends that built 69 390 s that went this route so thought I would mention it.
Offline mason1958
« Reply #5 on: November 23, 2017, 02:56:43 PM »
What you got Jeff ?
« Reply #6 on: November 25, 2017, 02:05:53 AM »
What you got Jeff ?
NOS in the box boxed in 1969 I believe
Bought a handful of them in the 90's from a high school that was given a bunch of parts for their automotive class in the late 60's. We're too much use any longer and were just taking up storage space so off they went
« Last Edit: November 25, 2017, 02:11:14 AM by J_Speegle »
Offline dearbornshow1968
« Reply #7 on: December 05, 2017, 12:29:51 PM »
that is how i got this carb but from a guy who worked for Ford  He went to dealerships for show and tell
Offline Hipo giddyup
« Reply #8 on: December 06, 2017, 02:02:10 PM »
Pretty sure you will be looking for a Autolite 4300,  C9ZF-C  . I'll have to double check my book when I get home to confirm that number. Let me see if I have an extra in my garage, I just might.
« Reply #9 on: December 06, 2017, 02:07:11 PM »
It might also be a C9OF-E # instead... maybe someone infront of their carb book can check quicker than me.  ;)
« Reply #10 on: December 06, 2017, 02:43:40 PM »
C9ZF-9510-E (C9ZF-E) would be correct for 1969 S code with manual transmission and IMCO.
« Reply #11 on: December 06, 2017, 06:42:43 PM »
As indicated in the Library under a spreadsheet titled - "Year - Engine - Carburetor List".
« Reply #12 on: December 06, 2017, 08:53:01 PM »
I checked my garage and have a C9ZF-F, for an automatic application. Sorry..
Offline mason1958
« Reply #13 on: December 08, 2017, 06:40:53 PM »
Oh well would love to have one for a manual application Mason
« Reply #14 on: December 08, 2017, 08:12:56 PM »
On the positive side this is a bolt on part that can be found, improved upon and swapped out later if you find one. As long as you don't have to modify other supporting items in the mean time. For showing in most concours classes the visible numbers should not produce a deduction as long as the physical characteristics are there. Meaning that if you install a carb designed for an automatic in this case and year you will see deductions if you don't modify it while a carb like the one I posted the picture of likely would not.
Sure that someone might even attempt to restamp bases and replace the id tags. Has been done before on other Autolite carbs in an effort to provide what is expected visually
« Last Edit: December 08, 2017, 08:15:40 PM by J_Speegle »
