Author Topic: Strut rod cup washers  (Read 2547 times)
Offline cobraboy
« on: August 23, 2010, 04:51:50 AM »
Hi Fellas
Which way round were the cup washers originaly fitted when the cars were assembled - cup toward the rubber or away?
What do you recommend if poly bushes are used ?
13th April 1965 Dearborn K GT on the other side of the pond.
Offline T Lea
Re: Strut rod cup washers
« Reply #1 on: August 23, 2010, 08:32:07 AM »
Toward the rubber. The ones that are cupped away (on the rear) are the Moog replacements. I don't know much about poly bushings, I only use the Ford ones
Offline cobraboy
« Reply #2 on: August 23, 2010, 05:27:37 PM »
Thank you
« Reply #3 on: August 23, 2010, 06:07:26 PM »
i would not recommend the poly bushings. they will put too much stress on the rod & it could break. i usually refinish & reuse the original washers & nut.
Offline cobraboy
« Reply #4 on: August 25, 2010, 12:45:33 PM »
Appreciate the tip
