Author Topic: Convertible vs Coupe 65-6 Trunk lid torsion rod  (Read 1259 times)
Offline MustangAndFairlane1867
« on: November 16, 2017, 12:10:43 PM »
If so, he used a lot of them.  I’ve see those on numerous ‘65s.  BTW, was the trunk lid tension rod arrangement—including brackets and fasteners, etc.—the same on coupes and convertibles of the same year?
Ron
Offline 65Ford
Re: Convertible vs Coupe 65-6 Trunk lid torsion rod
« Reply #1 on: November 18, 2017, 09:36:59 PM »
Not that I recall.  I think the coupe had two rods?
63A  R  28  02K  51  1  5
5R09A142
« Reply #2 on: November 19, 2017, 05:47:38 PM »
Split this discussion off from one focusing on 65-6 fastback trunk lid torsion rods
So here are some examples so you can draw your own conclusions
On coupes the two rods are held to the body midway between the drivers side and passenger side trunk hinges. On convertibles there thewre is no midway unpainted retainer/bracket
Coupe
Convertible
Comparison of hinges and rod locations
Drivers side coupe
Drivers side convertible
Passenger side coupe
Passenger side convertible
« Reply #3 on: November 19, 2017, 11:31:28 PM »
Not sure if there is a question about the difference between coupe and convertible torsion rods?  If so, they are definitely different, have run into the issue before.
« Reply #4 on: November 20, 2017, 02:56:21 AM »
Lookign at both but there appear to be shaped differently at the end that connects to the top of the hinge
« Reply #5 on: November 20, 2017, 12:20:31 PM »
Different part numbers in the 66 Mustang Body Assembly Manual would indicate a different design.
(Books are your friends too.)
