Author Topic: Trunk lid torsion rod 65 Fastback  (Read 1478 times)
Offline MustangAndFairlane1867
« on: November 14, 2017, 11:54:23 AM »
I have to remove the trunk lid on my '65 Mustang fastback and I've been repeatedly warned that the removal and replacement of the lid's torsion rod can be tricky and possibly even somewhat dangerous.  I've done several searches here and online but haven't been able to find a good primer or video on how to best approach this project.  If someone can point me in the right direction it would be very helpful.  Thanks in advance!  Ron
« Last Edit: May 23, 2020, 12:56:35 AM by J_Speegle »
Re: Trunk lid torsion rod
« Reply #1 on: November 14, 2017, 12:27:04 PM »
I've not had any problems, unless you don't prop up the lid. There are a couple of different types of rods so a picture of the ends would clue us in as to what to expect.
« Reply #2 on: November 14, 2017, 12:31:28 PM »
Thanks, Jim.  I'll get the pictures posted today.  FYI, the car had a February '65 assembly date in San Jose.  Ron...
« Reply #3 on: November 14, 2017, 05:45:42 PM »
As a related side note it appears from the estimated build period your car was at the point of transition between the factory using the electrical clip on the drivers end of the fastback trunk spring and them dropping that practice
« Reply #4 on: November 14, 2017, 06:47:12 PM »
An electrical clip?  What?  That makes no sense.  Can you show a picture?
« Reply #5 on: November 14, 2017, 07:16:03 PM »
Of course. Been discussed and pictures posted before
http://www.concoursmustang.com/forum/index.php?topic=6866.msg38841#msg38841
Reply #7
http://www.concoursmustang.com/forum/index.php?topic=7839.msg44851#msg44851
« Reply #6 on: November 14, 2017, 07:23:28 PM »
Another variation.
« Reply #7 on: November 14, 2017, 10:43:27 PM »
I'm Ron who started this thread with a promise to post pictures of my trunk lid torsion rod.  I'm still trying to figure out the best way to control the energy in this beast as I try to dismantle it and get my deck lid off.  If you've been-there-done-that with this early style torsion rod, I would really like to hear from you.  Thanks, Ron
« Reply #8 on: November 14, 2017, 11:12:43 PM »
Trying again to get all the pictures posted (I'm using Win10 picture app which drives me completely nuts);
« Reply #9 on: November 14, 2017, 11:15:25 PM »
One more Trunk lid Torsion rod pictures.  Apparently I can only post one at a time:
« Reply #10 on: November 14, 2017, 11:36:47 PM »
Done these more than a dozen times.  Just can't recall how I controlled the release - if I did control it, at the moment
Don't have any on the cars at home with the spring so can't go out and give it a look. Sure someone will offer and we'll go from there
And thanks for another data point for the spreadsheets
« Reply #11 on: November 16, 2017, 12:40:34 AM »
The clip appears to be 372047-S100, a common electrical wiring retainer. Coincidently, this clip is used on 65-66 Fastback wiring en-route to the trunk, which leads me to believe that some enterprising assembly line worker "borrowed" one (there were two) and put it to use solving the problem of the trunk lid torsion rod popping out.
