Author Topic: Strange Glove Box Door Bump  (Read 1947 times)
Offline steve_f
« on: August 22, 2010, 09:48:34 PM »
The glove box door on my May 15, 1965 SJ fastback has this strange bump in the middle just below the latch button.  At first I thought that the previous owner somehow jammed something in the glove box that pushed out the door.  The problem with that is that there is a corresponding bump, not a depression, on the inside of the door.  I have no idea what could have caused this.  Is the door really two pieces sandwiched together or is it all one casting?  I don't know if I should leave it, or replace the door.  It appears to be the original door.  Thanks.
Steve
Steve
1965 (15S) San Jose Mustang GT Fastback (sold)
Offline steve_f
Re: Strange Glove Box Door Bump
« Reply #1 on: August 24, 2010, 09:18:24 PM »
Does anyone know if the GT glove box door was originally two pieces assembled together, or a one piece casting?  Two pieces might explain the bump if something got in there in there during the assembly of the door.  If it's one piece then I don't know how it got there.
Steve
« Reply #2 on: August 24, 2010, 10:56:30 PM »
Doesn't look like a manufacturing defect, possibly damage?
The '65 GT glove box door was identical to the deluxe interior piece, simply sans the wood grain applique.  It was a single casting.
Offline steve_f
« Reply #3 on: August 24, 2010, 11:39:31 PM »
At first I thought it was damage.  There are no cracks on either side though.  If the door is a single casting then I have no ideas.  If it was damage then I would think that one side would be dented in.  Both the inside and outside of the door have a raised bump in the same place.
Steve
« Reply #4 on: August 25, 2010, 10:21:38 PM »
Definitely is an odd-ball.  I assume this is an original Ford part?
Offline steve_f
« Reply #5 on: August 25, 2010, 10:43:08 PM »
As far as I can tell it looks like the original door.  Since the door is a single casting could it have had an air bubble?  I bought the car from the original owner's wife.  He bought it new.  I would have thought he would have had the dealer replace it if it was there when he bought it.
Added the pic of the part number
« Last Edit: August 25, 2010, 10:48:18 PM by steve_f »
Steve
« Reply #6 on: August 26, 2010, 12:16:36 AM »
Definitely an OEM door.  One of those things that you might have to replace.  Don't want to be the guy with the car that has a glove box "pimple" do you?!   :o  ;D
Offline steve_f
« Reply #7 on: August 27, 2010, 02:40:24 PM »
Thanks Charles.  I've definitely thought about replacing it.  The car is pretty much an "early" GT survivor though so I have been trying to replace only what I need to.
Steve
