Author Topic: Hood hinge "color"  (Read 4051 times)
Re: Hood hinge "color"
« Reply #15 on: November 14, 2017, 07:36:15 PM »
Some pictures for color. The strut rods are the color-shade I like, and the picture was taken after they sat for a couple of years. The hinge was right after phosphate and oil. I like to use WD-40 spray as I flush out the pivot points until they run clear.
Offline MustangAndFairlane1867
« Reply #16 on: November 15, 2017, 12:38:04 PM »
Great pictures.  Thank you!  Ron
Offline Anghelrestorations
    • Anghel Restorations
« Reply #17 on: November 17, 2017, 12:56:43 AM »
I wrote this a few months back:
http://anghelrestorations.com/uploads/3/5/1/2/35122002/hood_hinges_v1.1.pdf
I do like Charles comment on the approximate switch over from black to phosphate for the early cars so will probably add that.
Marcus Anghel
www.anghelrestorations.com
« Reply #18 on: November 17, 2017, 06:23:12 AM »
If any help in identifying an original "color" of an unrestored example, perhaps these images of a couple NOS 67-early 68 Service Replacements can help. I would say the coloring seen in the "flash" area would be closest to what to expect to see in natural lighting (images otherwise are a bit dark). The date on the box below the hinges look to be 1991, fwiw, these are from Bob P.'s collection, so most likely they have been in a climate controlled setting for much of their life.
« Reply #19 on: November 17, 2017, 09:41:58 AM »
Haven't seen NOS hood hinges packaged in a box like that.  It might just be a box for something else that the hinges are on.  Hinges usually just had a wired part number tag or later 1980/90's ones had the silver Ford stickers.
« Reply #20 on: November 17, 2017, 11:37:16 AM »
Makes good sense...I had to wonder since the Service Replacement (NOS) early style hinges for 67-70 were extinct by 1969 or something very early on.
Offline 196667Bob
« Reply #21 on: November 17, 2017, 01:13:29 PM »
+1
I purchased Service Replacements from Ford in the early 80's, and received the C9ZZ ones in the attached pictures. As I remember, each came in its own box. Note too that they are painted. All of this makes sense since the true 1967 Service Parts (C7ZZ-16696/7-A) had a very short "life". The initial (as of January 1967) 1967 Service Parts were C3OZ-16796/7-C. These were not Replaced until August of 1967 when they became C7ZZ-16796/7-A's. Then, sometime between July of 1969 and July of 1970, the C7ZZ's were Replaced by the C9ZZ's. The C9ZZ's were available until at least 1990 (that is the newest OSI book that I have). Thus, it would be highly unlikely, if not impossible, to find C7ZZ hinges in a box dated 1991.
Sorry, I got "off track" with the talk about the '67 Hood Hinges, responding about them, and forgot to address the fact that this is in the "1964-1/2 to 1966" Section. The Hood Hinges for 1965 and 1966 were Part #'s C3OZ-16796/7-A. These were available under this Part # until sometime between 1981 and 1983, when they were Replaced by none other than the C9ZZ-16796/7-A ones ; yes, the same ones that replaced the C7ZZ ones some years earlier.
« Last Edit: November 17, 2017, 03:01:45 PM by 196667Bob »
MCA 04909
« Reply #22 on: November 17, 2017, 02:22:06 PM »
It's a shipping box. UPS, FedEx and the USPS don't like to ship items that move. Plus it protects the hinges from the shipper's "tender" care.
